Asus ROG G751JL-BSI7T28 Display Assembly Replacement
  1. Asus ROG G751JL-BSI7T28 Display Assembly Replacement, Back Panel: step 1, image 1 of 1
    • With the laptop closed, turn it upside-down so the bottom is facing up toward you.
  2. Asus ROG G751JL-BSI7T28 Display Assembly Replacement: step 2, image 1 of 3 Asus ROG G751JL-BSI7T28 Display Assembly Replacement: step 2, image 2 of 3 Asus ROG G751JL-BSI7T28 Display Assembly Replacement: step 2, image 3 of 3
    • Place a spudger into the notch, and pry the small triangular piece away from the laptop.
    • Using a Phillips #00 screwdriver, remove the single 3 mm screw.
    • Place a spudger beneath the back panel and pry it away from the laptop.
  3. Asus ROG G751JL-BSI7T28 Display Assembly Replacement, Display Assembly: step 3, image 1 of 2 Asus ROG G751JL-BSI7T28 Display Assembly Replacement, Display Assembly: step 3, image 2 of 2
    • Remove all 5mm Phillips #00 screws from the back cover.
  4. Asus ROG G751JL-BSI7T28 Display Assembly Replacement: step 4, image 1 of 2 Asus ROG G751JL-BSI7T28 Display Assembly Replacement: step 4, image 2 of 2
    • Use a spudger to pry the disc drive out of the laptop.
  5. Asus ROG G751JL-BSI7T28 Display Assembly Replacement: step 5, image 1 of 3 Asus ROG G751JL-BSI7T28 Display Assembly Replacement: step 5, image 2 of 3 Asus ROG G751JL-BSI7T28 Display Assembly Replacement: step 5, image 3 of 3
    • Open the laptop and turn it so that the ASUS logo is facing you.
    • Gently lift up the display hinge housing shroud, but don’t pull it completely away yet.
    • Disconnect the RGB light power cable in the shroud, now the shroud can be put aside.
  6. Asus ROG G751JL-BSI7T28 Display Assembly Replacement: step 6, image 1 of 3 Asus ROG G751JL-BSI7T28 Display Assembly Replacement: step 6, image 2 of 3 Asus ROG G751JL-BSI7T28 Display Assembly Replacement: step 6, image 3 of 3
    • Remove the 5mm Phillips #00 screws.
    • Lift up the silver hinge brackets on each side of the laptop.
  7. Asus ROG G751JL-BSI7T28 Display Assembly Replacement: step 7, image 1 of 2 Asus ROG G751JL-BSI7T28 Display Assembly Replacement: step 7, image 2 of 2
    • Remove the 5mm Phillips #00 screws from the hinges.
    • Detach the ribbon cable and remove the display assembly from the laptop.
Kristen Gismondi
91,868 Reputation
241 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,418 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 382
