Asus ROG G752V Wireless Card Replacement
Jeong
Jeong and 6 other contributors
Last updated on January 5, 2021
1 hour
Difficult
Introduction
Go to step 1
A wireless card is used to connect a computer to a wireless network (Wi-Fi).
If your Asus ROG G752V is giving a blue screen or the wireless card is damaged, this means that the wireless connection is not working and a repair is needed.
Before starting the guide below, it is important to disconnect the charger from the laptop and make sure that the laptop is completely shut off before starting.
Be sure to have all the specified tools that are listed below before starting the replacement process.
Now follow these steps below in order to fix the issue.
Parts
Tools
Show more…
  1. Asus ROG G752V Wireless Card Replacement, Keyboard: step 1, image 1 of 2 Asus ROG G752V Wireless Card Replacement, Keyboard: step 1, image 2 of 2
    Tool used on this step:
    • Make sure you disconnect the charger before starting this guide.
    • Using a pair of tweezers, remove all 11 rubber plugs off of the back cover.
  2. Asus ROG G752V Wireless Card Replacement: step 2, image 1 of 2 Asus ROG G752V Wireless Card Replacement: step 2, image 2 of 2
    • Using a Phillips #0 screwdriver, remove all twelve 5.2mm screws on the back of the laptop.
    • There is one 5.2 mm screw under the rubber plug in the middle.
  3. Asus ROG G752V Wireless Card Replacement: step 3, image 1 of 1
    • Pull up the rubber seal and the service cover will come off.
  4. Asus ROG G752V Wireless Card Replacement: step 4, image 1 of 1
    • Using the Phillips #00 screwdriver, remove the six 5.2 mm screws under the service cover.
  5. Asus ROG G752V Wireless Card Replacement: step 5, image 1 of 1
    • Using your hands, pull the optical drive out.
  6. Asus ROG G752V Wireless Card Replacement: step 6, image 1 of 2 Asus ROG G752V Wireless Card Replacement: step 6, image 2 of 2
    • Use the iFixit opening tool to pry apart the back panel from the main body of the laptop.
    • Start from the front side of the laptop and then continue to the side for easier access.
  7. Asus ROG G752V Wireless Card Replacement: step 7, image 1 of 2 Asus ROG G752V Wireless Card Replacement: step 7, image 2 of 2
    • Slowly pull out the keyboard while lifting it about an inch.
    • There are cables attached to the keyboard and motherboard. DO NOT lift it more than 2 inches above the laptop.
  8. Asus ROG G752V Wireless Card Replacement: step 8, image 1 of 3 Asus ROG G752V Wireless Card Replacement: step 8, image 2 of 3 Asus ROG G752V Wireless Card Replacement: step 8, image 3 of 3
    • Using an ESD safe tool, detach all 3 ribbon cables. To do so, lift up the cable up and out.
  9. Asus ROG G752V Wireless Card Replacement: step 9, image 1 of 2 Asus ROG G752V Wireless Card Replacement: step 9, image 2 of 2
    • Once the cables are detached, lift the keyboard about 2 inches up and remove it from the rest of the body.
    • Make sure that the screen is open like the photo. This will ensure that none of your laptop components will be bent.
  10. Asus ROG G752V Wireless Card Replacement, Wireless Card: step 10, image 1 of 3 Asus ROG G752V Wireless Card Replacement, Wireless Card: step 10, image 2 of 3 Asus ROG G752V Wireless Card Replacement, Wireless Card: step 10, image 3 of 3
    • Unscrew one 3mm Philips #00 screw on the wireless card.
  11. Asus ROG G752V Wireless Card Replacement: step 11, image 1 of 2 Asus ROG G752V Wireless Card Replacement: step 11, image 2 of 2
    • Using your hands, unlatch the wireless card by pulling it out toward the screen.
    • Gently wiggle the card and pull it out of the motherboard.
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 38
All Time: 3,328
