Asus ROG Spatha Switch Replacement
  1. Asus ROG Spatha Switch Replacement, Switch: step 1, image 1 of 2 Asus ROG Spatha Switch Replacement, Switch: step 1, image 2 of 2
    • Make sure the mouse is powered off.
    • If the green is visible like in the first photo, turn the switch to fully power down the device.
  2. Asus ROG Spatha Switch Replacement: step 2, image 1 of 2 Asus ROG Spatha Switch Replacement: step 2, image 2 of 2
    • Remove the screw covers.
  3. Asus ROG Spatha Switch Replacement: step 3, image 1 of 2 Asus ROG Spatha Switch Replacement: step 3, image 2 of 2
    • Using a Torx T10 driver, remove the four screws from the device.
  4. Asus ROG Spatha Switch Replacement: step 4, image 1 of 2 Asus ROG Spatha Switch Replacement: step 4, image 2 of 2
    • Flip the mouse over and remove the top plastic casing.
  5. Asus ROG Spatha Switch Replacement: step 5, image 1 of 3 Asus ROG Spatha Switch Replacement: step 5, image 2 of 3 Asus ROG Spatha Switch Replacement: step 5, image 3 of 3
    • After locating which switch you need to replace, grab the switch by the top and the bottom and carefully pull it out of the device.
Suhaib Rahman
446 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 10
Past 7 Days: 26
Past 30 Days: 116
All Time: 3,012
