Asus ROG Strix GL702VM-BHI7N09 Hard Drive Replacement
  1. Asus ROG Strix GL702VM-BHI7N09 Hard Drive Replacement, Back Panel: step 1, image 1 of 2 Asus ROG Strix GL702VM-BHI7N09 Hard Drive Replacement, Back Panel: step 1, image 2 of 2
    • Flip the laptop over to the back panel, with the serial numbers facing up.
    • Using a Phillips #1 screwdriver, remove the ten 12 mm screws from the back panel.
  2. Asus ROG Strix GL702VM-BHI7N09 Hard Drive Replacement: step 2, image 1 of 3 Asus ROG Strix GL702VM-BHI7N09 Hard Drive Replacement: step 2, image 2 of 3 Asus ROG Strix GL702VM-BHI7N09 Hard Drive Replacement: step 2, image 3 of 3
    • The snap seals don't need a lot of pressure to open, and may break if forced. Be gentle with the opening tool.
    • Wedge the sharp edge of the plastic opening tool into the seam between the back panel and the rest of the laptop, then gently pry the panel up.
    • There will be a snapping sound as you remove the back panel, but that is just the seal loosening.
    • Continue breaking the seals by sliding the plastic opening tool around the entire laptop under the seam until the back panel is free.
    • Once you have broken all the seals, carefully lift the panel off.
  3. Asus ROG Strix GL702VM-BHI7N09 Hard Drive Replacement, Hard Drive: step 3, image 1 of 1
    • Using a Phillips #1 screwdriver, remove the four 4 mm screws holding the hard drive.
  4. Asus ROG Strix GL702VM-BHI7N09 Hard Drive Replacement: step 4, image 1 of 1
    • Pull the hard drive directly away from the fan just above it.
    • The connecting pins should slide out easily, but you might have to move the hard drive around a bit to loosen the pins.
8 other people completed this guide.
Zach Langer
676 Reputation
4 Guides authored
Cal Poly, Team S13-G2, Forte Spring 2017 Member of Cal Poly, Team S13-G2, Forte Spring 2017
CPSU-FORTE-S17S13G2
4 Members
4 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 25
All Time: 7,107
