Asus ROG Strix GL702VS Fan Replacement
  1. Asus ROG Strix GL702VS Fan Replacement, Back Cover: step 1, image 1 of 1
    • Flip the computer so the bottom of the laptop is facing up.
  2. Asus ROG Strix GL702VS Fan Replacement: step 2, image 1 of 1
    • Remove the ten JIS #0 screws around the edge of the laptop.
    • The two bottom screws are slightly shorter
  3. Asus ROG Strix GL702VS Fan Replacement: step 3, image 1 of 2 Asus ROG Strix GL702VS Fan Replacement: step 3, image 2 of 2
    • Use a Jimmy to carefully free each side of the bottom casing.
  4. Asus ROG Strix GL702VS Fan Replacement: step 4, image 1 of 1
    • Lift up the back casing from the computer.
    • You may hear clicking or snapping sounds. This is just the plastic clips coming loose.
  5. Asus ROG Strix GL702VS Fan Replacement, Cooling Fans: step 5, image 1 of 3 Asus ROG Strix GL702VS Fan Replacement, Cooling Fans: step 5, image 2 of 3 Asus ROG Strix GL702VS Fan Replacement, Cooling Fans: step 5, image 3 of 3
    • Remove the four 4.8mm JIS #0 screws (two on each fan).
  6. Asus ROG Strix GL702VS Fan Replacement: step 6, image 1 of 3 Asus ROG Strix GL702VS Fan Replacement: step 6, image 2 of 3 Asus ROG Strix GL702VS Fan Replacement: step 6, image 3 of 3
    Tool used on this step:
    Buy
    • Remove the fan's connector on the motherboard using a pair of tweezers.
    • Be gentle, as the small clips and wires can be easily damaged.
  7. Asus ROG Strix GL702VS Fan Replacement: step 7, image 1 of 2 Asus ROG Strix GL702VS Fan Replacement: step 7, image 2 of 2
    • Gently lift each fan up and out of position.
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 13
All Time: 3,025
