Asus ROG Strix GL702VS LCD Screen (Display) Replacement
  1. Asus ROG Strix GL702VS LCD Screen (Display) Replacement, LCD Screen (Display): step 1, image 1 of 3 Asus ROG Strix GL702VS LCD Screen (Display) Replacement, LCD Screen (Display): step 1, image 2 of 3 Asus ROG Strix GL702VS LCD Screen (Display) Replacement, LCD Screen (Display): step 1, image 3 of 3
    • Remove the two screw stickers at the bottom corners of the screen.
    • Remove the two 4mm JIS #0 screws beneath the stickers.
  2. Asus ROG Strix GL702VS LCD Screen (Display) Replacement: step 2, image 1 of 3 Asus ROG Strix GL702VS LCD Screen (Display) Replacement: step 2, image 2 of 3 Asus ROG Strix GL702VS LCD Screen (Display) Replacement: step 2, image 3 of 3
    • Break the glue between the bezel and screen with a nylon spudger, working around the inside of the bezel.
    • Using an opening tool, lift up the bezel once the glue has been removed.
    • The plastic clips remain so it will have some resistance/snapping noises.
  3. Asus ROG Strix GL702VS LCD Screen (Display) Replacement: step 3, image 1 of 2 Asus ROG Strix GL702VS LCD Screen (Display) Replacement: step 3, image 2 of 2
    • Lift the plastic bezel off of the front display panel.
    • The plastic bezel will click when put back on the screen.
  4. Asus ROG Strix GL702VS LCD Screen (Display) Replacement: step 4, image 1 of 1
    • Remove the four interior 4mm JIS #0 screws from each of the four metal LCD tabs.
  5. Asus ROG Strix GL702VS LCD Screen (Display) Replacement: step 5, image 1 of 3 Asus ROG Strix GL702VS LCD Screen (Display) Replacement: step 5, image 2 of 3 Asus ROG Strix GL702VS LCD Screen (Display) Replacement: step 5, image 3 of 3
    • Once the LCD display is freed you can lift it up out of the casing.
    • Be careful as the cable remains attached.
  6. Asus ROG Strix GL702VS LCD Screen (Display) Replacement: step 6, image 1 of 2 Asus ROG Strix GL702VS LCD Screen (Display) Replacement: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • On the backside of the LCD, disconnect the LCD cable using a pair of tweezers.
    • Once fully disconnected, remove the LCD and replace it.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 2,073
