Asus ROG ZX50VW-BH17N10 CD Drive Replacement
  1. Asus ROG ZX50VW-BH17N10 CD Drive Replacement, CD Drive: step 1, image 1 of 1
    • Remove the 9 mm and 16 mm screws on the back panel using the Philips #1 screw driver.
  2. Asus ROG ZX50VW-BH17N10 CD Drive Replacement: step 2, image 1 of 3 Asus ROG ZX50VW-BH17N10 CD Drive Replacement: step 2, image 2 of 3 Asus ROG ZX50VW-BH17N10 CD Drive Replacement: step 2, image 3 of 3
    • Use the metal spudger to pry the back panel off.
  3. Asus ROG ZX50VW-BH17N10 CD Drive Replacement: step 3, image 1 of 1
    • The following screws are removed using the Phillips #1 screwdriver.
    • Remove the four 9 mm screws from the hard drive and use the black pull tab to remove it.
    • Remove the five 1.6 mm screws and three 9 mm screws from perimeter of the laptop's base.
    • Remove the 9 mm screw next to the RAM.
    • Flip the computer right-side up.
    • Caution when flipping the computer. Components may shift around and the hard drive will fall out if not removed prior to flipping.
  4. Asus ROG ZX50VW-BH17N10 CD Drive Replacement: step 4, image 1 of 3 Asus ROG ZX50VW-BH17N10 CD Drive Replacement: step 4, image 2 of 3 Asus ROG ZX50VW-BH17N10 CD Drive Replacement: step 4, image 3 of 3
    • Gently pry the keyboard off being careful not to tug at any of the inner ribbons.
    • Using a metal spudger may cause damage to the internal components to the device. The ribbons are very fragile and can be severed easily.
    • Detach the three ribbons connecting the motherboard and the keyboard. Do this by flipping up the white latch and pulling the ribbon out. There should be one latch per ribbon.
  5. Asus ROG ZX50VW-BH17N10 CD Drive Replacement: step 5, image 1 of 1
    • Gently remove the the keyboard.
    • Caution. There should be nothing attached to the keyboard at this point.
  6. Asus ROG ZX50VW-BH17N10 CD Drive Replacement: step 6, image 1 of 3 Asus ROG ZX50VW-BH17N10 CD Drive Replacement: step 6, image 2 of 3 Asus ROG ZX50VW-BH17N10 CD Drive Replacement: step 6, image 3 of 3
    • Use the metal spudger to push out the CD drive in the same direction it ejects.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 170
