Asus S500 USB, Headphone, and SD card Port board replacement
  1. Asus S500 USB, Headphone, and SD card Port board replacement, USB, Headphone, and SD card Ports: step 1, image 1 of 1
    • Unscrew the 10 screws on the back cover
  2. Asus S500 USB, Headphone, and SD card Port board replacement: step 2, image 1 of 1
    • Remove back cover (pry open along the grey/black line, they are held together by clips)
  3. Asus S500 USB, Headphone, and SD card Port board replacement: step 3, image 1 of 1
    • Lift up tab and pull out the connector
    • Unscrew the 4 screws
    • Open up the screen (as you would to open up the laptop), and in doing so the metal piece will open up.
    • Jostle the ports and remove the small board.
5 other people completed this guide.
Isaac Lemus
232 Reputation
1 Guide authored
2 Comments
where can i buy the usb mic part?
jorg123 - Reply
I have a [newish] 14” Asus 3 [Blue Al./gold trim]. One of my grandchildren has wrecked one of the usb 3.1 sockets on the right [Output] side.
Is it possible to renew this socket? I have all the tools + mini soldering iron. I could connect the remaining one to a usb hub I suppose but it’s an expensive machine and I would rather it be repaired.
Any help/advice very much appreciated. Regards - Denis
Denis TRAYNOR - Reply
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 21
All Time: 3,733
