Asus TUF Gaming FX705G Battery Replacement
  1. Asus TUF Gaming FX705G Battery Replacement, Back Cover: step 1, image 1 of 2 Asus TUF Gaming FX705G Battery Replacement, Back Cover: step 1, image 2 of 2
    • Remove the eleven Phillips #0 screws that secure the back cover.
  2. Asus TUF Gaming FX705G Battery Replacement: step 2, image 1 of 2 Asus TUF Gaming FX705G Battery Replacement: step 2, image 2 of 2
    • Use the iFixit opening tool to lift the back cover's seam, then insert the spudger parallel to the back cover and lift gently upward.
    • You will hear pops as the back cover releases.
  3. Asus TUF Gaming FX705G Battery Replacement, Battery: step 3, image 1 of 2 Asus TUF Gaming FX705G Battery Replacement, Battery: step 3, image 2 of 2
    • Remove the three Phillips #00 screws from the battery housing.
  4. Asus TUF Gaming FX705G Battery Replacement: step 4, image 1 of 2 Asus TUF Gaming FX705G Battery Replacement: step 4, image 2 of 2
    • Disconnect the wire from the motherboard, and lift the battery from its housing.
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 28
All Time: 6,585
