Asus TUF Gaming FX705G M.2 SSD Replacement
  1. Asus TUF Gaming FX705G M.2 SSD Replacement, Back Cover: step 1, image 1 of 2 Asus TUF Gaming FX705G M.2 SSD Replacement, Back Cover: step 1, image 2 of 2
    • Remove the eleven Phillips #0 screws that secure the back cover.
  2. Asus TUF Gaming FX705G M.2 SSD Replacement: step 2, image 1 of 2 Asus TUF Gaming FX705G M.2 SSD Replacement: step 2, image 2 of 2
    • Use the iFixit opening tool to lift the back cover's seam, then insert the spudger parallel to the back cover and lift gently upward.
    • You will hear pops as the back cover releases.
  3. Asus TUF Gaming FX705G M.2 SSD Replacement, Battery: step 3, image 1 of 2 Asus TUF Gaming FX705G M.2 SSD Replacement, Battery: step 3, image 2 of 2
    • Remove the three Phillips #00 screws from the battery housing.
  4. Asus TUF Gaming FX705G M.2 SSD Replacement: step 4, image 1 of 2 Asus TUF Gaming FX705G M.2 SSD Replacement: step 4, image 2 of 2
    • Disconnect the wire from the motherboard, and lift the battery from its housing.
  5. Asus TUF Gaming FX705G M.2 SSD Replacement, M.2 SSD: step 5, image 1 of 1
    • Remove the Phillips #00 screw on the left side of the M.2 SSD.
  6. Asus TUF Gaming FX705G M.2 SSD Replacement: step 6, image 1 of 1
    • Gently lift the screw side of the SSD to approximately a 45 degree angle and pull away from slot to remove it from the laptop.
3 other people completed this guide.
0 Comments
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 39
All Time: 4,107
