Asus Tablet MeMo Pad 7 ME7000C Speaker Replacement
  1. Asus Tablet MeMo Pad 7 ME7000C Speaker Replacement, Back Panel: step 1, image 1 of 2 Asus Tablet MeMo Pad 7 ME7000C Speaker Replacement, Back Panel: step 1, image 2 of 2
    • Flip over the tablet so the back cover is facing you. Hold the second button on the left below the volume buttons down until it powers off.
  2. Asus Tablet MeMo Pad 7 ME7000C Speaker Replacement: step 2, image 1 of 3 Asus Tablet MeMo Pad 7 ME7000C Speaker Replacement: step 2, image 2 of 3 Asus Tablet MeMo Pad 7 ME7000C Speaker Replacement: step 2, image 3 of 3
    • Beginning in the upper corner of the tablet, use the blue plastic opening tool and run it along the seam. Do this slowly so you don't cause damage to the device.
    • If you are having trouble using the blue plastic opening tools, try using the black spudger instead.
  3. Asus Tablet MeMo Pad 7 ME7000C Speaker Replacement: step 3, image 1 of 2 Asus Tablet MeMo Pad 7 ME7000C Speaker Replacement: step 3, image 2 of 2
    • Pull the rear panel and the display screen away from each other.
  4. Asus Tablet MeMo Pad 7 ME7000C Speaker Replacement, Battery: step 4, image 1 of 3 Asus Tablet MeMo Pad 7 ME7000C Speaker Replacement, Battery: step 4, image 2 of 3 Asus Tablet MeMo Pad 7 ME7000C Speaker Replacement, Battery: step 4, image 3 of 3
    • Using the spudger, gently press on the black button on the plug port to release the battery from the plug.
  5. Asus Tablet MeMo Pad 7 ME7000C Speaker Replacement: step 5, image 1 of 2 Asus Tablet MeMo Pad 7 ME7000C Speaker Replacement: step 5, image 2 of 2
    • Remove the battery from the device.
  6. Asus Tablet MeMo Pad 7 ME7000C Speaker Replacement, Speaker: step 6, image 1 of 2 Asus Tablet MeMo Pad 7 ME7000C Speaker Replacement, Speaker: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Using the tweezers, disconnect the black clip.
  7. Asus Tablet MeMo Pad 7 ME7000C Speaker Replacement: step 7, image 1 of 3 Asus Tablet MeMo Pad 7 ME7000C Speaker Replacement: step 7, image 2 of 3 Asus Tablet MeMo Pad 7 ME7000C Speaker Replacement: step 7, image 3 of 3
    • Use the Phillips #000 Screwdriver to unscrew the 3mm Phillips head screws on the right and left corners of the speaker.
    • Use the magnetic pad to keep track of your screws while working.
  8. Asus Tablet MeMo Pad 7 ME7000C Speaker Replacement: step 8, image 1 of 1
    • Remove the speaker from the device.
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 185
