Asus Transformer Book T100TAF Button Module Replacement
  1. Asus Transformer Book T100TAF Button Module Replacement, Button Module: step 1, image 1 of 1
    • Detach the keyboard from the screen by depressing the silver button on the hinge and pulling upwards on the tablet.
  2. Asus Transformer Book T100TAF Button Module Replacement: step 2, image 1 of 1
    • Insert the spudger behind the plastic backing of the tablet and then slide the spudger around the outside of the tablet, carefully releasing all internal clips.
  3. Asus Transformer Book T100TAF Button Module Replacement: step 3, image 1 of 2 Asus Transformer Book T100TAF Button Module Replacement: step 3, image 2 of 2
    • Locate the button module.
    • Remove the three black 3.5 mm Phillips screws.
  4. Asus Transformer Book T100TAF Button Module Replacement: step 4, image 1 of 1
    Tool used on this step:
    $3.99
    Buy
    • Flip up the clip holding the white ribbon cable in with the angled tweezers.
    • Gently pull the white ribbon cable away from the button module.
  5. Asus Transformer Book T100TAF Button Module Replacement: step 5, image 1 of 1
    • Lift the button module up and out of the device.
Elizabeth
589 Reputation
3 Guides authored
USF Tampa, Team 4-3, Passmore Fall 2016 Member of USF Tampa, Team 4-3, Passmore Fall 2016
USFT-PASSMORE-F16S4G3
4 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 8
All Time: 748
