Asus Transformer Pad Infinity LCD Display Replacement
  1. Asus Transformer Pad Infinity LCD Display Replacement, LCD Display: step 1, image 1 of 3 Asus Transformer Pad Infinity LCD Display Replacement, LCD Display: step 1, image 2 of 3 Asus Transformer Pad Infinity LCD Display Replacement, LCD Display: step 1, image 3 of 3
    • Disconnect the long silver ribbon connector from the screen.
    • Remove the orange ribbon connector with the two connections.
  2. Asus Transformer Pad Infinity LCD Display Replacement: step 2, image 1 of 1
    • Remove the 4 screws around the metal portion of the screen (this is the LCD display).
  3. Asus Transformer Pad Infinity LCD Display Replacement: step 3, image 1 of 1
    • Peel the orange ribbon back (it has adhesive sticking itself to the black electric tape looking stuff surrounding the metal portion).
  4. Asus Transformer Pad Infinity LCD Display Replacement: step 4, image 1 of 1
    • Carefully place a preferably plastic tool between the glass portion and the electric tape looking stuff and pry off the screen from that portion.
    • Note: Take care as you’re dealing directly with with the glass and the way your touch input gets into the device.
  5. Asus Transformer Pad Infinity LCD Display Replacement: step 5, image 1 of 1
    • Once removed, replace the LCD display back onto the glass screen (the new screen may or may not have new adhesive depending on where you got it.
    • If it doesn’t, make sure you secure it with the screws safely).
Allison Poh
549 Reputation
5 Guides authored
UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015 Member of UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G1
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 7
All Time: 1,130
