Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement
  1. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement, Rear/Front Facing Camera: step 1, image 1 of 3 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement, Rear/Front Facing Camera: step 1, image 2 of 3 Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement, Rear/Front Facing Camera: step 1, image 3 of 3
    • Flip the pieces that secure the ribbons to the motherboard up. This is for the front facing camera.
    • Take out the ribbon connected to the motherboard. This is for the rear camera.
    • Note: Only follow what is needed for the camera you are replacing. If both cameras need replacement, do both steps. Otherwise, follow the one designated for the camera you need to replace.
    • Note: The first photo shows the overall image. The second photo shows the step for the front facing camera. The third photo shows the step for the rear camera.
  2. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 2, image 1 of 1
    • Take the cameras out.
    • Note: They are stuck onto the case by little sticky pads.
  3. Asus Transformer Pad Infinity Rear/Front Facing Camera Replacement: step 3, image 1 of 1
    • Put the cameras back into their spot.
    • Note: It’s probably worth it here to make sure they are secure to the case so either re-use the old sticky pads or find some new ones.
Allison Poh
549 Reputation
5 Guides authored
UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015 Member of UMass Dartmouth, Team 5-1, Gulbrandsen Fall 2015
UMASSD-GULBRANDSEN-F15S5G1
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 5
All Time: 326
