Asus Transformer T100 Battery Replacement
  1. Asus Transformer T100 Battery Replacement, Rear Cover: step 1, image 1 of 2 Asus Transformer T100 Battery Replacement, Rear Cover: step 1, image 2 of 2
    • Separate the tablet from the base by pressing the large silver button below the tablet. The silver button is located at the base of the tablet.
    • Remove the tablet by lifting up.
  2. Asus Transformer T100 Battery Replacement: step 2, image 1 of 2 Asus Transformer T100 Battery Replacement: step 2, image 2 of 2
    • Insert the opening tool into the seam of the tablet casing and gently pry upwards.
    • With a little force, you will feel the clips release.
  3. Asus Transformer T100 Battery Replacement: step 3, image 1 of 1
    • Slide the tool along all four edges of the tablet, making sure that all the clips are released.
    • Do not break these clips; otherwise, the screen will become less secure.
  4. Asus Transformer T100 Battery Replacement: step 4, image 1 of 2 Asus Transformer T100 Battery Replacement: step 4, image 2 of 2
    • Remove the rear casing.
  5. Asus Transformer T100 Battery Replacement, Battery: step 5, image 1 of 1
    • Remove the copper tape carefully.
  6. Asus Transformer T100 Battery Replacement: step 6, image 1 of 2 Asus Transformer T100 Battery Replacement: step 6, image 2 of 2
    • Gently pull back the yellow transparent plastic covering on top of the battery connection port.
  7. Asus Transformer T100 Battery Replacement: step 7, image 1 of 3 Asus Transformer T100 Battery Replacement: step 7, image 2 of 3 Asus Transformer T100 Battery Replacement: step 7, image 3 of 3
    • Rotate the device so the top of the screen is facing you. Place the plastic opening tool underneath the battery and gently pry upwards to lift the battery out.
    • The battery wire harness will slide out as the battery is pried up.
  8. Asus Transformer T100 Battery Replacement: step 8, image 1 of 2 Asus Transformer T100 Battery Replacement: step 8, image 2 of 2
    • Remove the battery by slowly peeling the battery away from the connected side.
    • The adhesive on the back will pull away from the battery.
69 other people completed this guide.
Taylor Pantiga
1,617 Reputation
6 Guides authored
Cal Poly, Team 13-31, Maness Spring 2014 Member of Cal Poly, Team 13-31, Maness Spring 2014
CPSU-MANESS-S14S13G31
3 Members
8 Guides authored
22 Guide Comments
So I switched out my screen for it and its not turning on and I checked it everything was correctly place, but my Asus transformer was dead before hand so I tried charging it, and it wasn't charging, so I checked it and it seems the battery wire harness is loose enough to come off, is it possible to fix that?
christian cantu - Reply
Hi christian! How did you solve this problem? That happened to me too...
Matheus Moraes -
what is the battery part # for t100 and can you purchase it?
thank you
RJ - Reply
Part number is C12N1320. They are available from a variety of sources.
Jack Riggins - Reply
Thanks for detailed guide.
I could not get the transformer tablet to power up no matter which buttons I held for how long or in what sequence. Unplugging the battery internally and replugging fixed a hung device.
JPWhite - Reply
Past 24 Hours: 10
Past 7 Days: 65
Past 30 Days: 187
All Time: 131,933
