Asus Transformer T100 Button Module Replacement
  1. Asus Transformer T100 Button Module Replacement, Rear Cover: step 1, image 1 of 2 Asus Transformer T100 Button Module Replacement, Rear Cover: step 1, image 2 of 2
    • Separate the tablet from the base by pressing the large silver button below the tablet. The silver button is located at the base of the tablet.
    • Remove the tablet by lifting up.
  2. Asus Transformer T100 Button Module Replacement: step 2, image 1 of 2 Asus Transformer T100 Button Module Replacement: step 2, image 2 of 2
    • Insert the opening tool into the seam of the tablet casing and gently pry upwards.
    • With a little force, you will feel the clips release.
  3. Asus Transformer T100 Button Module Replacement: step 3, image 1 of 1
    • Slide the tool along all four edges of the tablet, making sure that all the clips are released.
    • Do not break these clips; otherwise, the screen will become less secure.
  4. Asus Transformer T100 Button Module Replacement: step 4, image 1 of 2 Asus Transformer T100 Button Module Replacement: step 4, image 2 of 2
    • Remove the rear casing.
  5. Asus Transformer T100 Button Module Replacement, Button Module: step 5, image 1 of 1
    Tool used on this step:
    Buy
    • Unclip the white connection clip using a pair of tweezers.
  6. Asus Transformer T100 Button Module Replacement: step 6, image 1 of 2 Asus Transformer T100 Button Module Replacement: step 6, image 2 of 2
    • Pull the connection apparatus from the connection clip on the board using a pair of tweezers.
  7. Asus Transformer T100 Button Module Replacement: step 7, image 1 of 1
    • Gently fold the connection apparatus back away from your work area.
  8. Asus Transformer T100 Button Module Replacement: step 8, image 1 of 3 Asus Transformer T100 Button Module Replacement: step 8, image 2 of 3 Asus Transformer T100 Button Module Replacement: step 8, image 3 of 3
    • Remove the screws using a Phillips Head #1 screwdriver.
    • Remove the power button module.
4 other people completed this guide.
Taylor Pantiga
1,617 Reputation
6 Guides authored
Cal Poly, Team 13-31, Maness Spring 2014 Member of Cal Poly, Team 13-31, Maness Spring 2014
CPSU-MANESS-S14S13G31
3 Members
8 Guides authored
1 Guide Comment
My problem is that when reinstalltng the back cover the button does not fit the button module to press the on/off switch. The switch works allright.
What can i do? At this moment I can only switch the tablet on after removing the back cover.
Rudolf Guys - Reply
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 21
All Time: 6,239
