Asus U56E-BBL6 RAM Replacement
  1. Asus U56E-BBL6 RAM Replacement, Back Panel: step 1, image 1 of 2 Asus U56E-BBL6 RAM Replacement, Back Panel: step 1, image 2 of 2
    • Using a Phillips #00 screwdriver, remove the screws.
  2. Asus U56E-BBL6 RAM Replacement: step 2, image 1 of 1
    • Lift backplate and remove from the case.
  3. Asus U56E-BBL6 RAM Replacement, RAM: step 3, image 1 of 1
    • Once inside the panel, locate your RAM sticks.
  4. Asus U56E-BBL6 RAM Replacement: step 4, image 1 of 2 Asus U56E-BBL6 RAM Replacement: step 4, image 2 of 2
    • This device is embedded with two RAM sticks.
    • Push the metal brackets carefully to release and remove the RAM stick .
  5. Asus U56E-BBL6 RAM Replacement: step 5, image 1 of 2 Asus U56E-BBL6 RAM Replacement: step 5, image 2 of 2
    • Repeat the previous step for removing the other RAM stick.
Josiah Allard
733 Reputation
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 235
