Asus UL30VT-A1 Hard Drive Replacement
  1. Asus UL30VT-A1 Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
    • Flip your device so that the back of the device is facing you.
  2. Asus UL30VT-A1 Hard Drive Replacement: step 2, image 1 of 2 Asus UL30VT-A1 Hard Drive Replacement: step 2, image 2 of 2
    • Remove the four screws using your Phillips #0 screwdriver to attain access to your Hard Drive.
    • Remove the panel using a plastic opening tool.
  3. Asus UL30VT-A1 Hard Drive Replacement: step 3, image 1 of 2 Asus UL30VT-A1 Hard Drive Replacement: step 3, image 2 of 2
    • Gently pull the black strip and the Hard Drive should slide right off. Pull your hard drive to the side not up to avoid damage to the slot.
Miguel Gonzalez
97 Reputation
1 Guide authored
Gateway, Team S1-G2, Saknee Spring 2019 Member of Gateway, Team S1-G2, Saknee Spring 2019
GCC-SAKNEE-S19S1G2
5 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 236
