Asus UL80VT Motherboard Replacement
  1. Asus UL80VT Motherboard Replacement, Battery: step 1, image 1 of 1
    • Flip the laptop so you can see the back side.
  2. Asus UL80VT Motherboard Replacement: step 2, image 1 of 2 Asus UL80VT Motherboard Replacement: step 2, image 2 of 2
    • Identify the two slide locks below the battery. Slide them outward towards the unlock symbol. You should see a red mark that indicates that the battery is unlocked and is ready for removal.
  3. Asus UL80VT Motherboard Replacement: step 3, image 1 of 1
    • Now you can remove the battery while continuing to hold the right battery lock in the unlock position.
  4. Asus UL80VT Motherboard Replacement, Hard Drive: step 4, image 1 of 3 Asus UL80VT Motherboard Replacement, Hard Drive: step 4, image 2 of 3 Asus UL80VT Motherboard Replacement, Hard Drive: step 4, image 3 of 3
    • Flip the computer over, and unscrew the two 5 mm screws using the Phillips #0 screwdriver.
    • Lift the panel from the device.
  5. Asus UL80VT Motherboard Replacement: step 5, image 1 of 2 Asus UL80VT Motherboard Replacement: step 5, image 2 of 2
    • Slide the hard drive away from the SATA connector and remove the hard drive from the device.
  6. Asus UL80VT Motherboard Replacement, RAM: step 6, image 1 of 1
    • Flip computer over and unscrew the two 5 mm screws using the Phillips #0 screwdriver.
  7. Asus UL80VT Motherboard Replacement: step 7, image 1 of 3 Asus UL80VT Motherboard Replacement: step 7, image 2 of 3 Asus UL80VT Motherboard Replacement: step 7, image 3 of 3
    • Pull the clips toward the chassis of the computer. The RAM will pop up and can easily be removed.
  8. Asus UL80VT Motherboard Replacement, Keyboard: step 8, image 1 of 2 Asus UL80VT Motherboard Replacement, Keyboard: step 8, image 2 of 2
    • Open laptop so the keyboard is accessible.
    • Insert a plastic prying tool and push and then pull to release the keyboard from the device.
  9. Asus UL80VT Motherboard Replacement: step 9, image 1 of 1
    • Lift keyboard and remove ZIF connector cables.
    • Remove the keyboard from the device.
  10. Asus UL80VT Motherboard Replacement, Motherboard: step 10, image 1 of 1
    • Remove the nine 5 mm screws using the Phillips #0 screwdriver.
  11. Asus UL80VT Motherboard Replacement: step 11, image 1 of 1
    • Flip the laptop over and remove nine 5 mm screws using the Phillips #0 screwdriver.
  12. Asus UL80VT Motherboard Replacement: step 12, image 1 of 2 Asus UL80VT Motherboard Replacement: step 12, image 2 of 2
    • Use the iFixit opening tool to remove the cd drive on the left of the laptop.
  13. Asus UL80VT Motherboard Replacement: step 13, image 1 of 1
    • Use the same tool to remove the plastic top from the laptop.
  14. Asus UL80VT Motherboard Replacement: step 14, image 1 of 1
    • Remove the eight 3 mm screws using the Phillips #0 screwdriver.
    • Lift up the motherboard and disconnect all wires attaching the motherboard to the rest of the computer.
  15. Asus UL80VT Motherboard Replacement: step 15, image 1 of 1
    • Lift the motherboard out of the laptop and remove it from the device.
2 other people completed this guide.
James DellaMorte
660 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 5
Past 30 Days: 16
All Time: 456
