Asus V6800V Keyboard Replacement
  1. Asus V6800V Keyboard Replacement, Battery: step 1, image 1 of 2 Asus V6800V Keyboard Replacement, Battery: step 1, image 2 of 2
    • Place the computer upside down.
    • Using your thumbs, slide both latches away from each other (towards the outside).
    • Push the battery out with your fingers.
    • The actual battery is not pictured.
  2. Asus V6800V Keyboard Replacement, Keyboard: step 2, image 1 of 1
    • Using a Phillips #0 screwdriver, remove the two screws from the case.
    • These screws should have a "K" symbol next to them.
  3. Asus V6800V Keyboard Replacement: step 3, image 1 of 3 Asus V6800V Keyboard Replacement: step 3, image 2 of 3 Asus V6800V Keyboard Replacement: step 3, image 3 of 3
    • Locate the four tabs above the F1, F10, INSERT, and between the F5 and F6 keys.
    • Starting with the tab above the F1 key, press the tabs inward using your fingernail or spudger. Continue this process for the rest of the tabs.
    • Once all four tabs have been released, the top half of the keyboard should be free.
  4. Asus V6800V Keyboard Replacement: step 4, image 1 of 2 Asus V6800V Keyboard Replacement: step 4, image 2 of 2
    • Pull the keyboard up from the top at a 45 degree angle. Place it upside down on the touchpad.
    • Pull the wide ribbon cable laterally from its socket on the motherboard to free the keyboard.
Steven
32 Reputation
2 Guides authored
Cal Poly, Team 2-9, Johann Summer 2010 Member of Cal Poly, Team 2-9, Johann Summer 2010
CPSU-JOHANN-R10S2G9
5 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 8
All Time: 5,088
