Asus VivoBook 14" F412DA RAM Replacement/Upgrade
  1. Asus VivoBook 14" F412DA RAM  Replacement/Upgrade, Remove the screws: step 1, image 1 of 1
    Tool used on this step:
    Anti-Static Wrist Strap
    $7.95
    Buy
    • Start by removing the marked screws:
    • Remove the four 6mm screws
    • Remove the two 8mm screws
    • Remove the four 9mm screws
    • These screws are different lengths, remember which order you removed them. Putting the wrong size screw in the wrong hole can cause damage.
    • The screw in the center is covered by a sticker that must be removed.
    • It is recommended to wear an anti-static wrist strap for this procedure.
    • Before you begin, make sure the new RAM is compatible. The RAM should be SODIMM DDR4 memory. Only up to a 16 GB modules are supported (for a total of 20GB)
  2. Asus VivoBook 14" F412DA RAM  Replacement/Upgrade, Remove the bottom: step 2, image 1 of 3 Asus VivoBook 14" F412DA RAM  Replacement/Upgrade, Remove the bottom: step 2, image 2 of 3 Asus VivoBook 14" F412DA RAM  Replacement/Upgrade, Remove the bottom: step 2, image 3 of 3
    • Using a opening tool, pry and lift at the edge of the bottom until you feel it open.
  3. Asus VivoBook 14" F412DA RAM  Replacement/Upgrade, Release battery connector: step 3, image 1 of 3 Asus VivoBook 14" F412DA RAM  Replacement/Upgrade, Release battery connector: step 3, image 2 of 3 Asus VivoBook 14" F412DA RAM  Replacement/Upgrade, Release battery connector: step 3, image 3 of 3
    • Using a fingernail or spudger move back the retaining clip holding the battery connector in place.
    • Be gentle releasing the connector, it's very fragile.
  4. Asus VivoBook 14" F412DA RAM  Replacement/Upgrade, Disconnect the battery: step 4, image 1 of 3 Asus VivoBook 14" F412DA RAM  Replacement/Upgrade, Disconnect the battery: step 4, image 2 of 3 Asus VivoBook 14" F412DA RAM  Replacement/Upgrade, Disconnect the battery: step 4, image 3 of 3
    • Put a spudger under the battery connector and twist, the connector should lift off.
    • Be sure to use a plastic spudger as to not risk damaging the motherboard or puncturing the battery.
  5. Asus VivoBook 14" F412DA RAM  Replacement/Upgrade, Remove the RAM module: step 5, image 1 of 3 Asus VivoBook 14" F412DA RAM  Replacement/Upgrade, Remove the RAM module: step 5, image 2 of 3 Asus VivoBook 14" F412DA RAM  Replacement/Upgrade, Remove the RAM module: step 5, image 3 of 3
    • First, push down the clips at the side of the memory. Once you have, the memory module should pop up. You can now remove the memory module.
  6. Asus VivoBook 14" F412DA RAM  Replacement/Upgrade, Inserting the New RAM: step 6, image 1 of 2 Asus VivoBook 14" F412DA RAM  Replacement/Upgrade, Inserting the New RAM: step 6, image 2 of 2
    • Line up the notch on the new memory module with the notch on the slot and insert the module at an angle.
    • Make sure the new RAM is compatible. The RAM should be SODIMM DDR4 memory. Only up to 16 GB modules are supported (for a total of 20GB)
  7. Asus VivoBook 14" F412DA RAM  Replacement/Upgrade, Inserting the New RAM: step 7, image 1 of 2 Asus VivoBook 14" F412DA RAM  Replacement/Upgrade, Inserting the New RAM: step 7, image 2 of 2
    • Once the RAM is inserted, gently push down on the module until you hear a click.
To reassemble your device, follow these steps in reverse order.
11 other people completed this guide.
Jonathan D Banwart
847 Reputation
2 Guides authored
10 Guide Comments
Hi! Thank you so much for this tutorial, I was curious if you know if this is compatible for every ASUS Vivobook 14 or if there may be versions which don't support ram upgrades? I was told to look on the bottom (before taking off the cover) for a labelled spot where the RAM goes, but I don't see it. Does that definitely mean it is not compatible to add more?
Isabella Joubert - Reply Share
Hi, Thank you for your guide
how many slot for add memory?
Voravit Chamchoy - Reply Share
There is one accessible memory slots on the laptop as shown in the guide.
Jonathan D Banwart - Share
I'm about to find out first hand, however, I have researched and I understand that once you safely remove the bottom cover for the laptop, there is a single slot available for a 260-pin DDR4 SODIMM ram card. My research indicates I can add 16GB of additional ram this way, for a total maximum of 20GB ram memory on this model.
Further, I also understand one can upgrade the SSD for more storage. That's my next upgrade on this laptop.
Jason D Meinhart - Reply Share
You are correct! There is one DDR4 SODIMM slot, You may add up to one 16GB stick for 20GB total. Only speeds up to 2666Mhz are supported. The SSD is upgradable although you will need a drive cloner.
Past 24 Hours: 13
Past 7 Days: 72
Past 30 Days: 360
All Time: 26,519
