Asus VivoBook E203MA-TBCL432B Battery Replacement
  1. Asus VivoBook E203MA-TBCL432B Battery Replacement, Back Panel: step 1, image 1 of 1
    • Position the laptop so that the bottom panel is facing upwards, the hinge is away from you, and the ASUS logo is against the table.
    • It will be easier to replace the battery if the laptop is closed.
  2. Asus VivoBook E203MA-TBCL432B Battery Replacement: step 2, image 1 of 3 Asus VivoBook E203MA-TBCL432B Battery Replacement: step 2, image 2 of 3 Asus VivoBook E203MA-TBCL432B Battery Replacement: step 2, image 3 of 3
    • Use a Phillips #0 screwdriver to remove the eight 5 mm screws on the back panel.
    • Remove the two 7 mm Phillips #0 screws.
    • The 8 screws marked in red are all of the same length, 5 mm, and should not be interchanged with the two longer 7 mm screws marked in orange.
  3. Asus VivoBook E203MA-TBCL432B Battery Replacement: step 3, image 1 of 3 Asus VivoBook E203MA-TBCL432B Battery Replacement: step 3, image 2 of 3 Asus VivoBook E203MA-TBCL432B Battery Replacement: step 3, image 3 of 3
    • Insert the iFixit opening tool in between the back panel and the rest of the laptop.
    • With the iFixit opening tool, lift the panel from the laptop body. Work your way around the device creating separation with the tool.
    • Once there is enough separation between the back panel and the device, gently pull off the back panel with your hands and completely remove it.
    • Make sure to use a plastic tool, not a metal one, so that you don't scratch the panel.
  4. Asus VivoBook E203MA-TBCL432B Battery Replacement, Battery: step 4, image 1 of 3 Asus VivoBook E203MA-TBCL432B Battery Replacement, Battery: step 4, image 2 of 3 Asus VivoBook E203MA-TBCL432B Battery Replacement, Battery: step 4, image 3 of 3
    • Now that the back panel is removed you can clearly see the battery and all of its connectors.
    • Begin by removing the silver ribbon cable along the back of the battery.
    • To disconnect it from the motherboard, lift the black tab on the Zero Insertion Force (ZIF) connector up and pull the cable away using the blue tab.
    • Disconnect the ribbon cable from the left side in the same way.
  5. Asus VivoBook E203MA-TBCL432B Battery Replacement: step 5, image 1 of 1
    • Remove the red and black wire along the bottom of the battery.
    • This does not need to be disconnected, only removed from the clamps along the bottom of the battery.
  6. Asus VivoBook E203MA-TBCL432B Battery Replacement: step 6, image 1 of 2 Asus VivoBook E203MA-TBCL432B Battery Replacement: step 6, image 2 of 2
    • Using the Phillips #0 screwdriver, remove the two 3 mm screws located at the top and left side of the battery.
  7. Asus VivoBook E203MA-TBCL432B Battery Replacement: step 7, image 1 of 3 Asus VivoBook E203MA-TBCL432B Battery Replacement: step 7, image 2 of 3 Asus VivoBook E203MA-TBCL432B Battery Replacement: step 7, image 3 of 3
    • Gently lift the battery being mindful of the one cable still connected to the motherboard.
    • With the battery lifted, pull the remaining connector going to the motherboard up, it should come out with little force.
8 other people completed this guide.
Jacob Aubertine
470 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 58
All Time: 5,948
