Asus VivoBook Flip 14 TP410U Hard Disk Drive Replacement
  1. Asus VivoBook Flip 14 TP410U Hard Disk Drive Replacement, Hard Disk Drive: step 1, image 1 of 1
    • Disconnect laptop from the power supply.
  2. Asus VivoBook Flip 14 TP410U Hard Disk Drive Replacement: step 2, image 1 of 1
    • Use a Phillips #00 screwdriver to remove the ten 6.4 mm screws from the bottom cover.
  3. Asus VivoBook Flip 14 TP410U Hard Disk Drive Replacement: step 3, image 1 of 2 Asus VivoBook Flip 14 TP410U Hard Disk Drive Replacement: step 3, image 2 of 2
    • Use a metal or nylon spudger to pry open the back cover on all sides.
    • Remove the back cover to access the inside where the hard disk drive is located.
  4. Asus VivoBook Flip 14 TP410U Hard Disk Drive Replacement: step 4, image 1 of 1
    • Locate the hard-drive.
    • Disconnect the hard disk drive from its connectors, and remove the drive.
    • Place the new HDD in the same location and orientation.
Justin Martel
159 Reputation
1 Guide authored
One Comment
Hey, do you by any chance have the reference for the battery in the Asus TP410U ? Thank you!
Matt JBOM - Reply
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 29
All Time: 1,470
