Asus VivoBook Q200E-BHI3T45 Battery Replacement
  1. Asus VivoBook Q200E-BHI3T45 Battery Replacement, Battery: step 1, image 1 of 2 Asus VivoBook Q200E-BHI3T45 Battery Replacement, Battery: step 1, image 2 of 2
    • Use a Phillips 0 screwdriver to remove nine Phillips screws from the back of the laptop (four 7mm from the top hinge, four 5mm from the bottom hinge, and one 10mm screw from the center).
  2. Asus VivoBook Q200E-BHI3T45 Battery Replacement: step 2, image 1 of 1
    • Use a plastic opening tool to pry the back panel off.
  3. Asus VivoBook Q200E-BHI3T45 Battery Replacement: step 3, image 1 of 2 Asus VivoBook Q200E-BHI3T45 Battery Replacement: step 3, image 2 of 2
    • Use a Phillips 0 screwdriver to remove the eight 5mm Phillips screws holding the battery in place.
  4. Asus VivoBook Q200E-BHI3T45 Battery Replacement: step 4, image 1 of 2 Asus VivoBook Q200E-BHI3T45 Battery Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Remove the ribbon cable with a pair of tweezers.
  5. Asus VivoBook Q200E-BHI3T45 Battery Replacement: step 5, image 1 of 1
    • Lift and remove the battery.
5 other people completed this guide.
Bryann Tan
877 Reputation
6 Guides authored
USF Tampa, Team 16-2, Eyestone Fall 2016 Member of USF Tampa, Team 16-2, Eyestone Fall 2016
USFT-EYESTONE-F16S16G2
3 Members
6 Guides authored
4 Comments
Hey I need help with getting the battery out with Asus Vivo-Book E406SA
James Bruzo - Reply
hi, i need a complete case for asus vivobook Q200E. Any help please
murphy - Reply
Need help getting the battery out of my E406sa
Patrick Flynn - Reply
could you show me how to unplug the connector without breaking it?
Deng Daniel - Reply
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 50
All Time: 15,413
