Asus VivoBook Q200E-BHI3T45 WLAN (Wireless Chip) Replacement
  1. Asus VivoBook Q200E-BHI3T45 WLAN (Wireless Chip) Replacement, Battery: step 1, image 1 of 2 Asus VivoBook Q200E-BHI3T45 WLAN (Wireless Chip) Replacement, Battery: step 1, image 2 of 2
    • Use a Phillips 0 screwdriver to remove nine Phillips screws from the back of the laptop (four 7mm from the top hinge, four 5mm from the bottom hinge, and one 10mm screw from the center).
  2. Asus VivoBook Q200E-BHI3T45 WLAN (Wireless Chip) Replacement: step 2, image 1 of 1
    • Use a plastic opening tool to pry the back panel off.
  3. Asus VivoBook Q200E-BHI3T45 WLAN (Wireless Chip) Replacement: step 3, image 1 of 2 Asus VivoBook Q200E-BHI3T45 WLAN (Wireless Chip) Replacement: step 3, image 2 of 2
    • Use a Phillips 0 screwdriver to remove the eight 5mm Phillips screws holding the battery in place.
  4. Asus VivoBook Q200E-BHI3T45 WLAN (Wireless Chip) Replacement: step 4, image 1 of 2 Asus VivoBook Q200E-BHI3T45 WLAN (Wireless Chip) Replacement: step 4, image 2 of 2
    Tool used on this step:
    Buy
    • Remove the ribbon cable with a pair of tweezers.
  5. Asus VivoBook Q200E-BHI3T45 WLAN (Wireless Chip) Replacement: step 5, image 1 of 1
    • Lift and remove the battery.
  6. Asus VivoBook Q200E-BHI3T45 WLAN (Wireless Chip) Replacement, WLAN (Wireless Chip): step 6, image 1 of 2 Asus VivoBook Q200E-BHI3T45 WLAN (Wireless Chip) Replacement, WLAN (Wireless Chip): step 6, image 2 of 2
    • Remove one 5mm screw using a PH0 Philips screwdriver.
  7. Asus VivoBook Q200E-BHI3T45 WLAN (Wireless Chip) Replacement: step 7, image 1 of 1
    Buy
    • Remove the cable by lifting upwards with a pair of tweezers.
  8. Asus VivoBook Q200E-BHI3T45 WLAN (Wireless Chip) Replacement: step 8, image 1 of 1
    • Remove the WLAN chip by pulling out parallel to the surface.
Bryann Tan
877 Reputation
6 Guides authored
USF Tampa, Team 16-2, Eyestone Fall 2016 Member of USF Tampa, Team 16-2, Eyestone Fall 2016
USFT-EYESTONE-F16S16G2
3 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 216
