Asus VivoBook Q200E-BSI3T08 Battery Replacement
  1. Asus VivoBook Q200E-BSI3T08 Battery Replacement, Back Panel: step 1, image 1 of 1
    • Turn off the computer and unplug the charge cable.
    • If the computer is on or plugged in, it could cause electric shock.
    • Turn the computer upside down.
  2. Asus VivoBook Q200E-BSI3T08 Battery Replacement: step 2, image 1 of 1
    • Remove the nine Philips #00 screws holding the back panel in place (four 5.6mm, four 7.7mm, and one 9.2mm).
  3. Asus VivoBook Q200E-BSI3T08 Battery Replacement: step 3, image 1 of 2 Asus VivoBook Q200E-BSI3T08 Battery Replacement: step 3, image 2 of 2
    • Use a plastic opening tool to gently remove the back panel.
  4. Asus VivoBook Q200E-BSI3T08 Battery Replacement, Battery: step 4, image 1 of 1
    • Remove the eight 4.7mm Philips #00 screws holding the battery in place.
  5. Asus VivoBook Q200E-BSI3T08 Battery Replacement: step 5, image 1 of 3 Asus VivoBook Q200E-BSI3T08 Battery Replacement: step 5, image 2 of 3 Asus VivoBook Q200E-BSI3T08 Battery Replacement: step 5, image 3 of 3
    • The battery is attached by a set of wires.
    • Use your finger to disconnect the set of wires. It should come off very easily.
  6. Asus VivoBook Q200E-BSI3T08 Battery Replacement: step 6, image 1 of 2 Asus VivoBook Q200E-BSI3T08 Battery Replacement: step 6, image 2 of 2
    • Now just lift the battery out of place.
14 other people completed this guide.
Maxim
462 Reputation
1 Guide authored
UWT Liner: Group 6 Member of UWT Liner: Group 6
Community
3 Members
1 Guide authored
2 Comments
Super helpful instructions. Especially mentioning which screws were different sizes, so I knew to keep the 3 different sizes for the back cover separated and noted which sizes went back where. Many thanks!
Albert Einstein - Reply
Great guide. Thanks!
weston.fisher - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 7,437
