Asus VivoBook Q302LA-BHI3T09 Fan Replacement
  1. Asus VivoBook Q302LA-BHI3T09 Fan Replacement, Fan: step 1, image 1 of 2 Asus VivoBook Q302LA-BHI3T09 Fan Replacement, Fan: step 1, image 2 of 2
    • Before doing a repair or replacement make sure the laptop is fully shut off.
    • Using the JIS #0 Screwdriver, unscrew the ten 10 mm screws that hold the back casing in place.
  2. Asus VivoBook Q302LA-BHI3T09 Fan Replacement: step 2, image 1 of 2 Asus VivoBook Q302LA-BHI3T09 Fan Replacement: step 2, image 2 of 2
    • Pry open the back casing using the opening tool along the side crevice.
    • Try to use the opening tool at multiple points. Lifting the back casing abruptly could damage the laptop.
  3. Asus VivoBook Q302LA-BHI3T09 Fan Replacement: step 3, image 1 of 3 Asus VivoBook Q302LA-BHI3T09 Fan Replacement: step 3, image 2 of 3 Asus VivoBook Q302LA-BHI3T09 Fan Replacement: step 3, image 3 of 3
    • Remove the following screws that mount the fan and heatsink to the motherboard:
    • Three 3.0 mm screws for the fan
    • Four 2.0 mm screws for the heatsink
    • The bottom of the heatsink will contain thermal paste. Avoid making contact with this as any dirt or oils can reduce the effectiveness of the cooler.
Carl Zuehlsdorf
116 Reputation
1 Guide authored
USF Tampa, Team S5-G5, Eyestone Spring 2018 Member of USF Tampa, Team S5-G5, Eyestone Spring 2018
USFT-EYESTONE-S18S5G5
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 18
All Time: 187
