Asus VivoBook S200E-RHI3T73 Battery Replacement
  1. Asus VivoBook S200E-RHI3T73 Battery Replacement, Battery: step 1, image 1 of 1
    • Use a metal spudger to pry the bottom panel open.
    • Be gentle around the edges.
    • Lift the back panel to expose the inside of the laptop.
  2. Asus VivoBook S200E-RHI3T73 Battery Replacement: step 2, image 1 of 2 Asus VivoBook S200E-RHI3T73 Battery Replacement: step 2, image 2 of 2
    • Using the same Phillips #0 screwdriver, remove the eight black 50mm screws surrounding the battery.
  3. Asus VivoBook S200E-RHI3T73 Battery Replacement: step 3, image 1 of 1
    Tool used on this step:
    Buy
    • Using a set of precision tweezers, lift the motherboard connector tab.
  4. Asus VivoBook S200E-RHI3T73 Battery Replacement: step 4, image 1 of 2 Asus VivoBook S200E-RHI3T73 Battery Replacement: step 4, image 2 of 2
    • Use a nylon spudger or your fingers to gently pry the battery up.
    • Remove the battery.
    • Metal spudgers can puncture an unprotected battery, potentially causing a fire.
3 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 25
All Time: 2,959
