Asus VivoBook S200E-RHI3T73 Keyboard Replacement
  1. Asus VivoBook S200E-RHI3T73 Keyboard Replacement, Keyboard: step 1, image 1 of 1
    • Use a Phillips #0 screwdriver to remove the nine 50mm screws and lift the panel.
    • Be aware of sharp metal edges once the panel is removed.
  2. Asus VivoBook S200E-RHI3T73 Keyboard Replacement: step 2, image 1 of 1
    • Use the Phillips #0 screwdriver to remove the twelve 50mm screws around the battery.
    • Gently remove the battery to avoid damage.
  3. Asus VivoBook S200E-RHI3T73 Keyboard Replacement: step 3, image 1 of 3 Asus VivoBook S200E-RHI3T73 Keyboard Replacement: step 3, image 2 of 3 Asus VivoBook S200E-RHI3T73 Keyboard Replacement: step 3, image 3 of 3
    Tool used on this step:
    Buy
    • Use the Phillips #0 screwdriver to remove the five 5mm screws around the fan.
    • Use the precision tweezers to unplug the fan cords.
    • Be cautious of pulling the cords.
  4. Asus VivoBook S200E-RHI3T73 Keyboard Replacement: step 4, image 1 of 3 Asus VivoBook S200E-RHI3T73 Keyboard Replacement: step 4, image 2 of 3 Asus VivoBook S200E-RHI3T73 Keyboard Replacement: step 4, image 3 of 3
    • Use the Phillips#0 screwdriver to unscrew the 3.5mm screws from around the motherboard and the 6mm screws from around the PCB.
    • Double check for unloosened screws. Bending the boards can damage the hardware.
  5. Asus VivoBook S200E-RHI3T73 Keyboard Replacement: step 5, image 1 of 2 Asus VivoBook S200E-RHI3T73 Keyboard Replacement: step 5, image 2 of 2
    • Use the Phillips#0 screwdriver to remove the 50mm screws on the boarder of the metal panel.
    • Be cautious of sharp metal edges.
    • Carefully remove the panel. Without care it will bend and be difficult to reassemble.
  6. Asus VivoBook S200E-RHI3T73 Keyboard Replacement: step 6, image 1 of 1
    • Using the Phillips#0 screwdriver, remove the 50mm screws surrounding the keyboard.
    • Gently remove the keyboard.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 615
