Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement
  1. Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement, Battery: step 1, image 1 of 1
    • Use a metal spudger to pry the bottom panel open.
    • Be gentle around the edges.
    • Lift the back panel to expose the inside of the laptop.
  2. Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: step 2, image 1 of 2 Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: step 2, image 2 of 2
    • Using the same Phillips #0 screwdriver, remove the eight black 50mm screws surrounding the battery.
  3. Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: step 3, image 1 of 1
    Tool used on this step:
    Buy
    • Using a set of precision tweezers, lift the motherboard connector tab.
  4. Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: step 4, image 1 of 2 Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: step 4, image 2 of 2
    • Use a nylon spudger or your fingers to gently pry the battery up.
    • Remove the battery.
    • Metal spudgers can puncture an unprotected battery, potentially causing a fire.
  5. Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement, Printed Circuit Board (PCB): step 5, image 1 of 1
    • Use a Phillips #0 screwdriver to remove the nine 50mm panel screws.
    • Gently remove back panel
    • Be aware of sharp metal edges once the panel is removed.
  6. Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: step 6, image 1 of 1
    • Use the Phillips #0 screwdriver to remove the 50mm screws around the battery.
    • Gently remove the battery to avoid damage.
  7. Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: step 7, image 1 of 2 Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: step 7, image 2 of 2
    • Use a Phillips #0 screwdriver to remove the five 5mm screws on the fan.
    • Peel the protective wire tape off of the multicolored wires.
  8. Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: step 8, image 1 of 2 Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: step 8, image 2 of 2
    Buy
    • Use the precision tweezers to disconnect the wires and gently remove the fan.
    • Be gentle so as not to break wires.
  9. Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: step 9, image 1 of 2 Asus VivoBook S200E-RHI3T73 Printed Circuit Board (PCB) Replacement: step 9, image 2 of 2
    • Use the Phillips #0 screwdriver to remove the eight 6mm PCB board screws.
    • Remove the PCB board.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 344
