Asus VivoBook S200E-RHI3T73 Screen Replacement
  1. Asus VivoBook S200E-RHI3T73 Screen Replacement, Screen: step 1, image 1 of 1
    • With the screen closed, place your laptop upside-down with the front facing you.
    • Remove the five black 80mm Phillips #0 screws.
    • Remove the four black 50mm Phillips #0 screws.
  2. Asus VivoBook S200E-RHI3T73 Screen Replacement: step 2, image 1 of 1
    • Use a metal spudger to pry the bottom panel open.
    • Be gentle around the edges.
    • Lift the back panel to expose the inside of the laptop.
  3. Asus VivoBook S200E-RHI3T73 Screen Replacement: step 3, image 1 of 1
    • Use a metal spudger to remove the clear screen protector from its backing.
    • Apply ample force along the bottom of the screen protector.
  4. Asus VivoBook S200E-RHI3T73 Screen Replacement: step 4, image 1 of 1
    • Using a Phillips #0 screwdriver, remove the four 2mm silver screws located at each of the four corners of the screen.
  5. Asus VivoBook S200E-RHI3T73 Screen Replacement: step 5, image 1 of 1
    Tool used on this step:
    Buy
    • Gently lift the screen up and over.
    • Use tweezers to remove the EX2 LVDS connector cable that connects the screen and the laptop.
    • Remove the screen.
4 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 17
All Time: 2,094
