Asus VivoBook S200E-RHI3T73 Touchpad Replacement
  1. Asus VivoBook S200E-RHI3T73 Touchpad Replacement, Touchpad: step 1, image 1 of 2 Asus VivoBook S200E-RHI3T73 Touchpad Replacement, Touchpad: step 1, image 2 of 2
    • In order to remove the back lid, you must lay the laptop down with the lid closed and remove the screws with a Phillips #0 screwdriver.
    • There are five 80mm screws.
    • There are four 50mm screws.
    • Pull the back lid off of the laptop using your fingers.
  2. Asus VivoBook S200E-RHI3T73 Touchpad Replacement: step 2, image 1 of 2 Asus VivoBook S200E-RHI3T73 Touchpad Replacement: step 2, image 2 of 2
    • There should be a total of twelve 50mm screws when removing the battery.
    • The battery does not have to be fully removed for this step, however the screws must be taken out and the battery lifted.
  3. Asus VivoBook S200E-RHI3T73 Touchpad Replacement: step 3, image 1 of 2 Asus VivoBook S200E-RHI3T73 Touchpad Replacement: step 3, image 2 of 2
    • Use the Phillips #0 screwdriver to remove the six screws attached to the silver panel.
    • Disconnect the LED ribbon wires using a spudger to lift the clamp.
  4. Asus VivoBook S200E-RHI3T73 Touchpad Replacement: step 4, image 1 of 2 Asus VivoBook S200E-RHI3T73 Touchpad Replacement: step 4, image 2 of 2
    • Using the Phillips #0 screwdriver, remove the four screws on the silver panel.
    • Using a spudger, gently lift the silver ground strips off of the touch pad.
    • Pull the touch pad up and towards the battery to remove it from the laptop.
Katherine Nasci
124 Reputation
1 Guide authored
IUPUI, Team S9-G9, Wilson Spring 2019 Member of IUPUI, Team S9-G9, Wilson Spring 2019
IUPUI-WILSON-S19S9G9
4 Members
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 758
