Asus VivoBook S200E-RHI3T73 Wifi Chip Replacement
  1. Asus VivoBook S200E-RHI3T73 Wifi Chip Replacement, Wifi Chip: step 1, image 1 of 1
    • With the screen closed, place your laptop upside-down with the front facing you.
    • Remove the five black 80mm Phillips #0 screws.
    • Remove the four black 50mm Phillips #0 screws.
  2. Asus VivoBook S200E-RHI3T73 Wifi Chip Replacement: step 2, image 1 of 1
    • Use a metal spudger to pry the bottom panel open.
    • Be gentle around the edges.
    • Lift the back panel to expose the inside of the laptop.
  3. Asus VivoBook S200E-RHI3T73 Wifi Chip Replacement: step 3, image 1 of 1
    • Use a Phillips J0 screwdriver to remove the one black 3mm screw.
  4. Asus VivoBook S200E-RHI3T73 Wifi Chip Replacement: step 4, image 1 of 1
    • Use an up and away motion to pull the module out of its slot.
  5. Asus VivoBook S200E-RHI3T73 Wifi Chip Replacement: step 5, image 1 of 1
    Tool used on this step:
    Buy
    • Use precision tweezers to pry the black wire with a gold plug off the main gold plug on the module.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 697
