Asus VivoBook X202E-DB21T Hard Drive Replacement
  1. Asus VivoBook X202E-DB21T Hard Drive Replacement, Battery: step 1, image 1 of 2 Asus VivoBook X202E-DB21T Hard Drive Replacement, Battery: step 1, image 2 of 2
    • Flip the device such that the labels are on top.
    • Use a Phillips #1 screwdriver to remove the four 8mm screws near the back.
    • Use the same screwdriver to remove the four 5mm screws in the front.
    • Use the same screwdriver to remove the single 9mm screw in the center.
    • Make sure that the device is powered down and unplugged.
  2. Asus VivoBook X202E-DB21T Hard Drive Replacement: step 2, image 1 of 2 Asus VivoBook X202E-DB21T Hard Drive Replacement: step 2, image 2 of 2
    • Remove the back cover by gently prying with a spudger.
  3. Asus VivoBook X202E-DB21T Hard Drive Replacement: step 3, image 1 of 2 Asus VivoBook X202E-DB21T Hard Drive Replacement: step 3, image 2 of 2
    • Remove the eight 5mm screws using a Phillips #1 screwdriver.
    • Do not puncture the battery.
  4. Asus VivoBook X202E-DB21T Hard Drive Replacement: step 4, image 1 of 1
    • Disconnect the battery ribbon cable from the motherboard.
  5. Asus VivoBook X202E-DB21T Hard Drive Replacement: step 5, image 1 of 1
    • Remove the battery from the laptop.
  6. Asus VivoBook X202E-DB21T Hard Drive Replacement, Hard Drive: step 6, image 1 of 2 Asus VivoBook X202E-DB21T Hard Drive Replacement, Hard Drive: step 6, image 2 of 2
    • Unscrew the three 4mm screws holding the hard drive to the board.
  7. Asus VivoBook X202E-DB21T Hard Drive Replacement: step 7, image 1 of 2 Asus VivoBook X202E-DB21T Hard Drive Replacement: step 7, image 2 of 2
    • Pull on the tab on the left side of the hard drive and slowly disconnect it from the board.
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 19
All Time: 1,003
