Asus VivoBook X540N HDD to SSD Replacement
  1. Asus VivoBook X540N HDD to SSD Replacement, Opening the laptop: step 1, image 1 of 3 Asus VivoBook X540N HDD to SSD Replacement, Opening the laptop: step 1, image 2 of 3 Asus VivoBook X540N HDD to SSD Replacement, Opening the laptop: step 1, image 3 of 3
    • First of all you need to remove the 10 screws holding the laptop together.
    • Then use plastic or metal spudger to separate the bottom cover from the keyboard and touchpad assembly.
    • Once you open it, carefully unplug the keyboard and touchpad connectors. Be very careful not to damage them!
  2. Asus VivoBook X540N HDD to SSD Replacement: step 2, image 1 of 3 Asus VivoBook X540N HDD to SSD Replacement: step 2, image 2 of 3 Asus VivoBook X540N HDD to SSD Replacement: step 2, image 3 of 3
    • Once you open it, it should look like this.
    • You need to unscrew the only screw (marked in red) to be able to remove the HDD.
    • When you do that, just unscrew the 4 screws attatching the HDD to the bracket and replace it with the new one.
2 other people completed this guide.
Simeon Brankov
6,448 Reputation
51 Guides authored
4 Comments
Pls. Do more tutorial like this. It is very helpful to lack of knowledge person ?..
Would you mind to complete your tutorial regarding disassemble / assemble of this laptop model ?
For example : processor replacement
Heat sink replacement LCD replacement
Battery replacement
Hinges replacement
Thanks In Advance !
More Power !
Gilbert Gutierrez - Reply
Hello,
Im glad that you found the information useful. Unfortunately this laptop is no longer with me, if I come across the same model again, Ill be sure to make a more advanced tutorial.
Thank you and have a nice day :)
Simeon Brankov -
Sorry, I tried to replace it and the bios does not recognize it.
David - Reply
Hello,
This can indicate a problem with the SSD itself and/or the drivers on your laptop. Have you tried to load the drivers manually during Windows installation?
Simeon Brankov -
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 58
All Time: 1,817
