Asus VivoBook X540SA-BPD0602V Display Replacement
  1. Asus VivoBook X540SA-BPD0602V Display Replacement, Keyboard: step 1, image 1 of 1
    • Power down the laptop using the device's power button in top right corner of the keyboard. Ensure that the device's power cord is disconnected.
  2. Asus VivoBook X540SA-BPD0602V Display Replacement: step 2, image 1 of 1
    • Flip the laptop over so the back panel is displayed.
  3. Asus VivoBook X540SA-BPD0602V Display Replacement: step 3, image 1 of 1
    • Using a Phillips #1 screwdriver, remove the ten screws from the back panel.
    • Remove the two battery screws (15.6 mm)
    • Two top corner screws (12.5 mm)
    • Six case screws (9.7mm)
  4. Asus VivoBook X540SA-BPD0602V Display Replacement: step 4, image 1 of 1
    • Flip the laptop back over and open it, revealing the screen and keyboard.
  5. Asus VivoBook X540SA-BPD0602V Display Replacement: step 5, image 1 of 1
    • Using the blue plastic opening tool, wedge and loosen the seal all the way around the edges. Carefully lift up the keyboard panel.
    • When lifting the keyboard panel, do not lift it all the way as the two connection ribbons to the motherboard must be disconnected.
    • It is recommended to break the seal of the case starting at the upper corners closest to the display monitor .
  6. Asus VivoBook X540SA-BPD0602V Display Replacement: step 6, image 1 of 1
    • Observe where the ribbons connect to the motherboard, there are two connections. Each connection has a black clamp. To remove the ribbon, lift the black clamp up to disconnect it.
  7. Asus VivoBook X540SA-BPD0602V Display Replacement, Battery: step 7, image 1 of 1
    • Very carefully, remove the batteries with the blue plastic iFixit opening tool. Focus removing the battery near the highlighted area.
    • The batteries should all be connected to one another and come out of the device as a single unit.
    • Be careful not to rip any of the black plastic covering the batteries. Exposed battery parts can lead to explosions. If the case is ripped, re-wrap them, or properly dispose of them. Do not reuse them.
  8. Asus VivoBook X540SA-BPD0602V Display Replacement, Display: step 8, image 1 of 2 Asus VivoBook X540SA-BPD0602V Display Replacement, Display: step 8, image 2 of 2
    Tool used on this step:
    Buy
    • Use tweezers to remove small plastic screw covers from the bottom corners of the screen.
  9. Asus VivoBook X540SA-BPD0602V Display Replacement: step 9, image 1 of 1
    • Using the Phillips #0 screwdriver, remove the screws (3.8mm) from the bottom corners of the screen.
  10. Asus VivoBook X540SA-BPD0602V Display Replacement: step 10, image 1 of 2 Asus VivoBook X540SA-BPD0602V Display Replacement: step 10, image 2 of 2
    • Gently go around the screen and pry the plastic frame away with the metal spudger.
    • Before disconnecting the bottom edge of the plastic frame, be sure to disconnect it from the laptop's hinges.
    • Be careful with the metal spudger in this process--it is easy to cause damage to the device with this tool.
  11. Asus VivoBook X540SA-BPD0602V Display Replacement: step 11, image 1 of 2 Asus VivoBook X540SA-BPD0602V Display Replacement: step 11, image 2 of 2
    • Remove screws (3.5mm) from the four corners of the screen, utilizing Phillips #0 screwdriver.
  12. Asus VivoBook X540SA-BPD0602V Display Replacement: step 12, image 1 of 1
    • Gently pull the display away from where it is seated in the device.
    • Note that there is a connection to the motherboard at the bottom of the display. Take care not to pull too hard on this connection when removing the display.
  13. Asus VivoBook X540SA-BPD0602V Display Replacement: step 13, image 1 of 1
    • Rotate the display to expose the motherboard connection at the bottom of the display, and disconnect.
    • There may be tape supporting the connection which must be removed first if present.
2 other people completed this guide.
Taylor Peters
309 Reputation
2 Guides authored
IUPUI, Team S2-G6, Harley Fall 2018 Member of IUPUI, Team S2-G6, Harley Fall 2018
IUPUI-HARLEY-F18S2G6
3 Members
4 Guides authored
One Comment
Hello, going through your step-by-step instructions and also seeing the appropriate tools and kit you have on your website for repairs, I've come to the conclusion that you folks are really good. Can you please help me with this same device model's touchpad not working. I mean ASUS Vivobook X540SA touchpad. There isn't any answer even on Microsoft Forum/community and I have tried almost all possible solution too.
Ed Tamakloe - Reply
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 41
All Time: 2,327
