Asus VivoTab Smart Camera Replacement
  1. Asus VivoTab Smart Camera Replacement, Motherboard: step 1, image 1 of 3 Asus VivoTab Smart Camera Replacement, Motherboard: step 1, image 2 of 3 Asus VivoTab Smart Camera Replacement, Motherboard: step 1, image 3 of 3
    • Power off the device before you begin disassembly.
    • Place the device face down on a flat surface.
    • Remove the back panel with the plastic opening tool by sliding the tool around the edge of the panel.
  2. Asus VivoTab Smart Camera Replacement: step 2, image 1 of 3 Asus VivoTab Smart Camera Replacement: step 2, image 2 of 3 Asus VivoTab Smart Camera Replacement: step 2, image 3 of 3
    Tool used on this step:
    Buy
    • Unplug the ribbon that connects to the camera by pulling outward on it with tweezers.
    • Remove the silver plate that sits on top of the camera lens.
  3. Asus VivoTab Smart Camera Replacement: step 3, image 1 of 3 Asus VivoTab Smart Camera Replacement: step 3, image 2 of 3 Asus VivoTab Smart Camera Replacement: step 3, image 3 of 3
    • Use tweezers to grab the speaker cable near the white plug and pull to disconnect it.
  4. Asus VivoTab Smart Camera Replacement: step 4, image 1 of 2 Asus VivoTab Smart Camera Replacement: step 4, image 2 of 2
    • Gently pull outward on the ribbon to with tweezers to disconnect it.
  5. Asus VivoTab Smart Camera Replacement: step 5, image 1 of 3 Asus VivoTab Smart Camera Replacement: step 5, image 2 of 3 Asus VivoTab Smart Camera Replacement: step 5, image 3 of 3
    • Peel back the tape covering the ribbons.
  6. Asus VivoTab Smart Camera Replacement: step 6, image 1 of 3 Asus VivoTab Smart Camera Replacement: step 6, image 2 of 3 Asus VivoTab Smart Camera Replacement: step 6, image 3 of 3
    • Unplug the 3 ribbons by pulling outward on them with a pair of tweezers.
  7. Asus VivoTab Smart Camera Replacement: step 7, image 1 of 3 Asus VivoTab Smart Camera Replacement: step 7, image 2 of 3 Asus VivoTab Smart Camera Replacement: step 7, image 3 of 3
    • Remove two 2.7 mm Phillips #00 screws holding down the pressure plate.
    • Use tweezers to lift back the battery connector, which is located directly under the pressure plate.
  8. Asus VivoTab Smart Camera Replacement: step 8, image 1 of 2 Asus VivoTab Smart Camera Replacement: step 8, image 2 of 2
    • Remove seven 3.7 mm Phillips #00 screws.
    • Remove one 2.7 mm Phillips #00 screw.
  9. Asus VivoTab Smart Camera Replacement: step 9, image 1 of 2 Asus VivoTab Smart Camera Replacement: step 9, image 2 of 2
    • Slide the tweezers under the motherboard and lift up to remove the motherboard.
  10. Asus VivoTab Smart Camera Replacement, Camera: step 10, image 1 of 1
    • Flip the motherboard over and lay it flat on a surface
  11. Asus VivoTab Smart Camera Replacement: step 11, image 1 of 2 Asus VivoTab Smart Camera Replacement: step 11, image 2 of 2
    Buy
    • Use tweezers to gently lift and remove the camera from the motherboard.
Zach Hatten
563 Reputation
4 Guides authored
USF Tampa, Team 2-4, Sullivan Fall 2016 Member of USF Tampa, Team 2-4, Sullivan Fall 2016
USFT-SULLIVAN-F16S2G4
4 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 18
All Time: 495
