Asus Vivobook Flip 14 TP410U LCD Assembly Replacement
  1. Asus Vivobook Flip 14 TP410U LCD Assembly Replacement, LCD Assembly: step 1, image 1 of 1
    • Turn off the power and disconnected the AC cable from the laptop.
  2. Asus Vivobook Flip 14 TP410U LCD Assembly Replacement: step 2, image 1 of 2 Asus Vivobook Flip 14 TP410U LCD Assembly Replacement: step 2, image 2 of 2
    • Remove the rubber covers for the two screws located at the bottom of the screen.
    • Use a Phillips #00 screwdriver to remove the two 6.4 mm screws outlined in the image.
  3. Asus Vivobook Flip 14 TP410U LCD Assembly Replacement: step 3, image 1 of 2 Asus Vivobook Flip 14 TP410U LCD Assembly Replacement: step 3, image 2 of 2
    • Excessive force may cause damage to connections.
    • Rotate the screen 360 degrees for ease of access.
    • Place the opening tool at the corner of where the screen meets the base of the laptop.
    • Pry open the screen along the edge until it is completely off the front cover.
    • Disconnect each appropriate connector while opening up the laptop.
  4. Asus Vivobook Flip 14 TP410U LCD Assembly Replacement: step 4, image 1 of 2 Asus Vivobook Flip 14 TP410U LCD Assembly Replacement: step 4, image 2 of 2
    • Excessive force should avoided since damage may accrue.
    • Remove the cable that connects to the touch display, front camera, and motherboard.
    • Remove each piece of tape that holds down each cable.
  5. Asus Vivobook Flip 14 TP410U LCD Assembly Replacement: step 5, image 1 of 1
    • Have the new LCD display fully unboxed and ready to be used.
    • Remove the old LCD display.
    • The touch screen sensor is extremely fragile, make sure to not put excessive force on the cable while assembling.
2 other people completed this guide.
Dominic Bento
326 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 34
All Time: 888
