Asus Vivobook Max X541SA-PD0703X Battery Replacement
  1. Asus Vivobook Max X541SA-PD0703X Battery Replacement, Hard Drive: step 1, image 1 of 1
    • Flip the laptop upside down so that the back of the laptop faces you.
  2. Asus Vivobook Max X541SA-PD0703X Battery Replacement: step 2, image 1 of 1
    • Remove the following ten Phillips #0 screws from the bottom of the laptop:
    • Six 13mm screws.
    • Four 11mm screws.
  3. Asus Vivobook Max X541SA-PD0703X Battery Replacement: step 3, image 1 of 3 Asus Vivobook Max X541SA-PD0703X Battery Replacement: step 3, image 2 of 3 Asus Vivobook Max X541SA-PD0703X Battery Replacement: step 3, image 3 of 3
    • Using a plastic opening tool, pry up the palm rest from the bottom case of the laptop.
    • Don't completely remove as there are ribbon cables connecting the two halves.
  4. Asus Vivobook Max X541SA-PD0703X Battery Replacement: step 4, image 1 of 3 Asus Vivobook Max X541SA-PD0703X Battery Replacement: step 4, image 2 of 3 Asus Vivobook Max X541SA-PD0703X Battery Replacement: step 4, image 3 of 3
    • Use a spudger to flip up the retaining flaps on both keyboard ribbon cable ZIF sockets.
    • Pull the ribbon cables out of their sockets.
  5. Asus Vivobook Max X541SA-PD0703X Battery Replacement: step 5, image 1 of 1
    • Remove the three 6mm Phillips #0 screws from the motherboard.
  6. Asus Vivobook Max X541SA-PD0703X Battery Replacement: step 6, image 1 of 2 Asus Vivobook Max X541SA-PD0703X Battery Replacement: step 6, image 2 of 2
    • Pull the Wi-Fi card out of the motherboard.
  7. Asus Vivobook Max X541SA-PD0703X Battery Replacement: step 7, image 1 of 1
    • Remove the hard drive by pulling it towards the right, and removing it from the laptop case
  8. Asus Vivobook Max X541SA-PD0703X Battery Replacement, Disc Drive: step 8, image 1 of 1
    • Remove the disc drive by sliding it towards the right and removing it from the laptop case
  9. Asus Vivobook Max X541SA-PD0703X Battery Replacement, Motherboard: step 9, image 1 of 2 Asus Vivobook Max X541SA-PD0703X Battery Replacement, Motherboard: step 9, image 2 of 2
    • Remove the three 6mm Phillips #0 screws from the fan shroud.
    • Remove the shroud from the motherboard.
  10. Asus Vivobook Max X541SA-PD0703X Battery Replacement: step 10, image 1 of 1
    • Pull the metal casing to the right.
    • Be careful when pulling the case because it may break the motherboard.
  11. Asus Vivobook Max X541SA-PD0703X Battery Replacement: step 11, image 1 of 2 Asus Vivobook Max X541SA-PD0703X Battery Replacement: step 11, image 2 of 2
    • There is a wire attached to the screen display.
    • Peel the sticker and disconnect it from the motherboard.
  12. Asus Vivobook Max X541SA-PD0703X Battery Replacement: step 12, image 1 of 1
    • Remove the plastic covering off of the motherboard.
  13. Asus Vivobook Max X541SA-PD0703X Battery Replacement: step 13, image 1 of 1
    • Remove the five 6mm Phillips #0 screws from the motherboard.
  14. Asus Vivobook Max X541SA-PD0703X Battery Replacement: step 14, image 1 of 2 Asus Vivobook Max X541SA-PD0703X Battery Replacement: step 14, image 2 of 2
    • Remove the cables connected to the motherboard by unplugging them using a plastic opening tool, or by hand.
  15. Asus Vivobook Max X541SA-PD0703X Battery Replacement: step 15, image 1 of 1
    • Pull the motherboard to the right and lift up.
  16. Asus Vivobook Max X541SA-PD0703X Battery Replacement, Battery: step 16, image 1 of 1
    • Remove the 6mm Phillips #0 screw from the battery bracket.
  17. Asus Vivobook Max X541SA-PD0703X Battery Replacement: step 17, image 1 of 1
    • Use a plastic opening tool to remove the battery from the laptop.
3 other people completed this guide.
Hetvi Mehta
781 Reputation
5 Guides authored
USF Tampa, Team S1-G4, Cagle Spring 2018 Member of USF Tampa, Team S1-G4, Cagle Spring 2018
USFT-CAGLE-S18S1G4
4 Members
7 Guides authored
4 Comments
Finished so simple, guide was easy to follow. Thank you
Forever R Holdings - Reply
Who was the idiot who designed this laptop? Remove the motherboard to replace the battery? Unbelievable.
Greg Worrel - Reply
I have a dead cmos battery and it seems i need to replace the whole battery
Wint3r xxx -
Sir how do I replace my cmos battery? Is it integrated with the battery. I also have Asus Vivobook Max X541SA-PD0703X
Wint3r xxx - Reply
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 23
All Time: 5,109
