Asus Vivobook Max X541SA-PD0703X Track Pad Replacement
  1. Asus Vivobook Max X541SA-PD0703X Track Pad Replacement, Keyboard: step 1, image 1 of 1
    • Flip the laptop upside down so that the back of the laptop faces you.
  2. Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: step 2, image 1 of 1
    • Remove the following ten Phillips #0 screws from the bottom of the laptop:
    • Six 13mm screws.
    • Four 11mm screws.
  3. Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: step 3, image 1 of 2 Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: step 3, image 2 of 2
    • Using a plastic opening tool, pry up the palm rest form the bottom half of the laptop.
    • Ribbon cables connect the two half so don't remove completely.
  4. Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: step 4, image 1 of 3 Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: step 4, image 2 of 3 Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: step 4, image 3 of 3
    • Use a spudger to flip up the retaining flap on the keyboard ribbon cable ZIF sockets.
    • Pull the ribbon cables out of their sockets.
  5. Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: step 5, image 1 of 1
    • Take the keyboard half of the laptop and place it in front of you so that they keys are facing down.
  6. Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: step 6, image 1 of 1
    • Remove the three 3mm Phillips #0 screws from the touchpad.
  7. Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: step 7, image 1 of 1
    • Use a spudger to flip up the retaining flap on the touch pad ribbon cable ZIF socket.
    • Pull the ribbon out of the socket.
  8. Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: step 8, image 1 of 2 Asus Vivobook Max X541SA-PD0703X Track Pad Replacement: step 8, image 2 of 2
    • Remove the touchpad.
Hetvi Mehta
781 Reputation
5 Guides authored
USF Tampa, Team S1-G4, Cagle Spring 2018 Member of USF Tampa, Team S1-G4, Cagle Spring 2018
USFT-CAGLE-S18S1G4
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 479
