Asus Vivobook Q301LA-BHI5T02 Hard Drive Replacement
  1. Asus Vivobook Q301LA-BHI5T02 Hard Drive Replacement, Back Cover: step 1, image 1 of 1
    • Make sure the computer is turned off.
    • Flip the device over so that the back cover is facing you.
  2. Asus Vivobook Q301LA-BHI5T02 Hard Drive Replacement: step 2, image 1 of 2 Asus Vivobook Q301LA-BHI5T02 Hard Drive Replacement: step 2, image 2 of 2
    • Remove the four 5mm Phillips #1 screws from the top of the laptop.
    • Remove the two 6mm Phillips #1 screws from the sides of the laptop.
    • Remove the four 2mm Phillips #1 screws from the bottom of the laptop.
  3. Asus Vivobook Q301LA-BHI5T02 Hard Drive Replacement: step 3, image 1 of 3 Asus Vivobook Q301LA-BHI5T02 Hard Drive Replacement: step 3, image 2 of 3 Asus Vivobook Q301LA-BHI5T02 Hard Drive Replacement: step 3, image 3 of 3
    • Use a plastic opening tool to gently pry the bottom of the laptop up. Slowly slide it along the edges, twisting it every so often to pop the bottom of the laptop out of the clips holding it in place.
  4. Asus Vivobook Q301LA-BHI5T02 Hard Drive Replacement: step 4, image 1 of 1
    • Lift off the cover and remove the back cover from the device.
  5. Asus Vivobook Q301LA-BHI5T02 Hard Drive Replacement, Hard Drive: step 5, image 1 of 1
    • Slide the hard drive out of the SATA port and remove it from the device.
Samuel Foster
157 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 789
