Asus Vivobook Q302LA-BHI3T09 Battery Replacement
  1. Asus Vivobook Q302LA-BHI3T09 Battery Replacement, Battery: step 1, image 1 of 2 Asus Vivobook Q302LA-BHI3T09 Battery Replacement, Battery: step 1, image 2 of 2
    • Before doing a replacement, make sure the laptop is fully shut off.
    • Using the JIS #0 Screwdriver, unscrew the ten 10 mm screws that hold the back casing in place.
  2. Asus Vivobook Q302LA-BHI3T09 Battery Replacement: step 2, image 1 of 2 Asus Vivobook Q302LA-BHI3T09 Battery Replacement: step 2, image 2 of 2
    • Pry open the back casing using the opening tool along the side crevice.
    • Try to use the opening tool at multiple points. Lifting the back casing abruptly could damage the laptop.
  3. Asus Vivobook Q302LA-BHI3T09 Battery Replacement: step 3, image 1 of 2 Asus Vivobook Q302LA-BHI3T09 Battery Replacement: step 3, image 2 of 2
    • Using the JIS #0 Screwdriver, remove the five 5.0 mm screws that hold down the battery.
  4. Asus Vivobook Q302LA-BHI3T09 Battery Replacement: step 4, image 1 of 2 Asus Vivobook Q302LA-BHI3T09 Battery Replacement: step 4, image 2 of 2
    • Disconnect the cable connected to the motherboard.
    • To remove, lift the ends using the opening tool.
Aymane Elbernoussi
160 Reputation
1 Guide authored
USF Tampa, Team S5-G5, Eyestone Spring 2018 Member of USF Tampa, Team S5-G5, Eyestone Spring 2018
USFT-EYESTONE-S18S5G5
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 526
