Asus W2W-A1 Hard Drive Replacement
  1. Asus W2W-A1 Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
    • Before disassembly, make sure the laptop is powered off and the battery is disconnected.
    • Remove the two screws (size?) on the lower panel at the bottom of the laptop (identify tool to use).
  2. Asus W2W-A1 Hard Drive Replacement: step 2, image 1 of 1
    • Grab the panel and lift upwards while pulling towards yourself.
  3. Asus W2W-A1 Hard Drive Replacement: step 3, image 1 of 1
    • Remove the 3 4 mm Phillips upper screws holding the hard drive down.
  4. Asus W2W-A1 Hard Drive Replacement: step 4, image 1 of 1
    • Pull the hard drive towards yourself to disconnect it from the laptop.
  5. Asus W2W-A1 Hard Drive Replacement: step 5, image 1 of 1
    • Lift the hard drive upwards to remove it from the laptop.
Nolan Schock
501 Reputation
5 Guides authored
Cal Poly, Team 13-29, Maness Spring 2014 Member of Cal Poly, Team 13-29, Maness Spring 2014
CPSU-MANESS-S14S13G29
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 303
