Asus X200CA Motherboard and RAM Replacement
  1. Asus X200CA Motherboard and RAM Replacement, Keyboard: step 1, image 1 of 2 Asus X200CA Motherboard and RAM Replacement, Keyboard: step 1, image 2 of 2
    • Remove the 8 black 4.7mm screws securing the keyboard to the bottom cover.
    • Remove the black 14.5mm screw from the center of the bottom cover.
  2. Asus X200CA Motherboard and RAM Replacement: step 2, image 1 of 1
    • Wedge a metal spudger between the keyboard and bottom cover and slide it around the perimeter until all edges separate.
  3. Asus X200CA Motherboard and RAM Replacement: step 3, image 1 of 1
    • Pull apart the keyboard and the bottom cover using your hands.
    • The keyboard and trackpad cables are still connected to the mainboard via a ZIF connector. Carefully disconnect them before completely removing the keyboard to prevent damage to the board or cables.
  4. Asus X200CA Motherboard and RAM Replacement, Motherboard and RAM: step 4, image 1 of 1
    • Remove the black plastic cover.
  5. Asus X200CA Motherboard and RAM Replacement: step 5, image 1 of 2 Asus X200CA Motherboard and RAM Replacement: step 5, image 2 of 2
    • Remove the 10 black 4.7mm screws holding the motherboard/RAM in place using a Phillips #00 screwdriver.
  6. Asus X200CA Motherboard and RAM Replacement: step 6, image 1 of 2 Asus X200CA Motherboard and RAM Replacement: step 6, image 2 of 2
    Tool used on this step:
    Buy
    • Use tweezers to separate the 2 sliding connectors and the ribbon cable connector.
  7. Asus X200CA Motherboard and RAM Replacement: step 7, image 1 of 2 Asus X200CA Motherboard and RAM Replacement: step 7, image 2 of 2
    • Use fingers to grab the black tape tab and pull back to disconnect the battery connector.
  8. Asus X200CA Motherboard and RAM Replacement: step 8, image 1 of 1
    • Lift the motherboard/RAM out from the frame.
7 other people completed this guide.
Jacqueline Collier
1,047 Reputation
5 Guides authored
USF Tampa, Team S1-G2, Leahy Fall 2017 Member of USF Tampa, Team S1-G2, Leahy Fall 2017
USFT-LEAHY-F17S1G2
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 99
All Time: 8,851
