Asus X200CA-HCL 1104G Battery Replacement
  1. Asus X200CA-HCL 1104G Battery Replacement, Battery: step 1, image 1 of 1
    • Using the Phillips 1 screwdriver, remove the laptop's back panel.
    • The parts you see underneath that panel are called the laptop's "internals".
  2. Asus X200CA-HCL 1104G Battery Replacement: step 2, image 1 of 1
    • The battery will be easily visible towards to top of the internals. It is a long, black rectangle marked "Li-ion". Notice that the battery is currently secured by three screws. We will need to unscrew them in order to remove the battery.
  3. Asus X200CA-HCL 1104G Battery Replacement: step 3, image 1 of 1
    • You will notice that there are two gold screws and one silver screw holding the battery in place. Using the Phillips 1 screwdriver, remove the silver screw.
    • For the gold screws, pliers may be necessary. Be careful not to cut yourself on them; they can be finicky.
    • From here, the battery will lift easily out of the laptop.
Samantha Wahl
301 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 13
All Time: 434
