Asus X200CA-HCL 1104G Motherboard Replacement
  1. Asus X200CA-HCL 1104G Motherboard Replacement, Motherboard: step 1, image 1 of 2 Asus X200CA-HCL 1104G Motherboard Replacement, Motherboard: step 1, image 2 of 2
    • Using the Phillips 1 screwdriver, remove the laptop's back panel.
    • Pry open the Keyboard/Touch pad.
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  2. Asus X200CA-HCL 1104G Motherboard Replacement: step 2, image 1 of 1
    • Detach keyboard and touch screen cables
    • These are the cable that are holding the keyboard and touch screen together
  3. Asus X200CA-HCL 1104G Motherboard Replacement: step 3, image 1 of 1
    • Remove the following four screws: Four 4 mm Phillips #0 using a phillips screwdriver.
    • Slide out the hard drive
  4. Asus X200CA-HCL 1104G Motherboard Replacement: step 5, image 1 of 1
    • Detach speaker
  5. Asus X200CA-HCL 1104G Motherboard Replacement: step 6, image 1 of 1
    • Remove motherboard screws
    • These would be located on the green panel which is the motherboard
    • Carefully remove motherboard
Svetlana Pimentel
201 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 10
All Time: 409
