Asus X200CA-HCL 1104G Speaker Replacement
  1. Asus X200CA-HCL 1104G Speaker Replacement, Speaker: step 1, image 1 of 1
    • Using the Phillips 1 screwdriver, remove the laptop's back panel.
    • Pry open the Keyboard/Touch pad.
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  2. Asus X200CA-HCL 1104G Speaker Replacement: step 2, image 1 of 1
    • Detach keyboard and touch screen cables
    • These are the cable that are holding the keyboard and touch screen together
  3. Asus X200CA-HCL 1104G Speaker Replacement: step 3, image 1 of 1
    • Unclip the connector that is located above touch screen
  4. Asus X200CA-HCL 1104G Speaker Replacement: step 4, image 1 of 1
    Tool used on this step:
    Buy
    • Use tweezers to remove the speaker bar that is located beneath the touch screen.
    • Once removed carefully disconnect the clip to the left of the speaker.
Svetlana Pimentel
201 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 11
All Time: 299
