Asus X200MA Battery Replacement
  1. Asus X200MA Battery Replacement, Back Panel: step 1, image 1 of 1
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
  2. Asus X200MA Battery Replacement: step 2, image 1 of 1
    • Take two rubber caps off the back side of the laptop.
    • Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
  3. Asus X200MA Battery Replacement: step 3, image 1 of 1
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  4. Asus X200MA Battery Replacement, Battery: step 4, image 1 of 1
  5. Asus X200MA Battery Replacement: step 5, image 1 of 1
    • Remove the following two screws under the rubber caps.
    • Two 14 mm screws using the Phillips #0 screw driver.
  6. Asus X200MA Battery Replacement: step 6, image 1 of 1
    • Flip up the following:
    • The two latches holding the two cables shown(white and black)
    • Pull the cables free from the latches
    • Lift the keyboard from the computer
  7. Asus X200MA Battery Replacement: step 7, image 1 of 1
    • Remove the following screws from the inside of the laptop:
    • Two 4 mm screws using the Phillips #0 phillips screwdriver.
    • One 5 mm screw using the Phillips #0 Phillips screwdriver located in the center a little below the battery.
  8. Asus X200MA Battery Replacement: step 8, image 1 of 1
    • Slide the battery up and out.
30 other people completed this guide.
Vanessa Garcia
1,796 Reputation
6 Guides authored
Cal Poly, Team 21-24, Maness Winter 2015 Member of Cal Poly, Team 21-24, Maness Winter 2015
CPSU-MANESS-W15S21G24
4 Members
8 Guides authored
8 Guide Comments
Thanks for the write up! Easy to follow, Great photos, and worked great!
nathaniel forward - Reply
thanks it worked
iqbal nasution - Reply
Your step by step instructions were so easy to follow. Great job. Thanks! :)
Fernando H - Reply
I would like to buy a battery to it, Please suggest me the best portal site
jagadeeshkumar maddala - Reply
Past 24 Hours: 8
Past 7 Days: 20
Past 30 Days: 68
All Time: 36,650
