Asus X200MA Hard Drive Replacement
Vanessa Garcia
Vanessa Garcia and 5 other contributors
Last updated on November 17, 2022
15 minutes
Moderate
Better Introduction
Fix Kits
These kits contain all the parts and tools needed to complete this guide.
Parts
Tools
  • Spudger
    Spudger
  • Phillips #0 Screwdriver
Show more…
  1. Asus X200MA Hard Drive Replacement, Back Panel: step 1, image 1 of 1
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
  2. Asus X200MA Hard Drive Replacement: step 2, image 1 of 1
    • Take two rubber caps off the back side of the laptop.
    • Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
  3. Asus X200MA Hard Drive Replacement: step 3, image 1 of 1
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  4. Asus X200MA Hard Drive Replacement, Hard Drive: step 4, image 1 of 1
    • Remove the black foam and adhesive located on top of the hard drive.
  5. Asus X200MA Hard Drive Replacement: step 5, image 1 of 1
    • Remove the following four screws:
    • Four 4 mm Phillips #0 using a phillips screwdriver.
  6. Asus X200MA Hard Drive Replacement: step 6, image 1 of 1
    • Slide out the hard drive
3 other people completed this guide.
Vanessa Garcia
1,796 Reputation
6 Guides authored
Cal Poly, Team 21-24, Maness Winter 2015 Member of Cal Poly, Team 21-24, Maness Winter 2015
CPSU-MANESS-W15S21G24
4 Members
8 Guides authored
2 Comments
You FORGOT TO MENTION that one must remove the 2 Rubber feet to get at 2 more screws :-(((((((
Matthew Miller - Reply
Very poor!!! If you follow this instruction, you will destroy your Laptop. I did nearly destroying it. You did not show the 2 screws under the rubbers.
Minus 1000 points!!!
luft_ha - Reply
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 22
All Time: 9,468
