Asus X200MA Motherboard Replacement
  1. Asus X200MA Motherboard Replacement, Back Panel: step 1, image 1 of 1
    • Remove the following six screws:
    • Six 4 mm screws using a Phillips #0 screwdriver.
    • Remove the following one screw:
    • One 14 mm screw using a Phillips #0 screwdriver.
    • The 14mm screw goes in the center.
  2. Asus X200MA Motherboard Replacement: step 2, image 1 of 1
    • Take two rubber caps off the back side of the laptop.
    • Use a Phillips #0 screwdriver to remove the two 14 mm screws under the rubber caps.
  3. Asus X200MA Motherboard Replacement: step 3, image 1 of 1
    • Use a plastic or metal spudger to separate the keyboard from the back panel and lift the keyboard out of place.
  4. Asus X200MA Motherboard Replacement, Battery: step 4, image 1 of 1
  5. Asus X200MA Motherboard Replacement: step 5, image 1 of 1
    • Remove the following two screws under the rubber caps.
    • Two 14 mm screws using the Phillips #0 screw driver.
  6. Asus X200MA Motherboard Replacement: step 6, image 1 of 1
    • Flip up the following:
    • The two latches holding the two cables shown(white and black)
    • Pull the cables free from the latches
    • Lift the keyboard from the computer
  7. Asus X200MA Motherboard Replacement: step 7, image 1 of 1
    • Remove the following screws from the inside of the laptop:
    • Two 4 mm screws using the Phillips #0 phillips screwdriver.
    • One 5 mm screw using the Phillips #0 Phillips screwdriver located in the center a little below the battery.
  8. Asus X200MA Motherboard Replacement: step 8, image 1 of 1
    • Slide the battery up and out.
  9. Asus X200MA Motherboard Replacement, Fan: step 9, image 1 of 1
    • Remove the Two 4 mm screws using Phillips #0 phillips screwdriver.
  10. Asus X200MA Motherboard Replacement: step 10, image 1 of 2 Asus X200MA Motherboard Replacement: step 10, image 2 of 2
    • Unplug the set of wires located at bottom corner on fan.
  11. Asus X200MA Motherboard Replacement: step 11, image 1 of 2 Asus X200MA Motherboard Replacement: step 11, image 2 of 2
    • Lift up and out to completely the remove fan component.
  12. Asus X200MA Motherboard Replacement, Motherboard: step 12, image 1 of 1
    • Use Phillips #0 screwdriver to remove the eight 4.0 mm screws.
  13. Asus X200MA Motherboard Replacement: step 13, image 1 of 2 Asus X200MA Motherboard Replacement: step 13, image 2 of 2
    • Pull back the blue ribbon, freeing it from the latch.
  14. Asus X200MA Motherboard Replacement: step 14, image 1 of 3 Asus X200MA Motherboard Replacement: step 14, image 2 of 3 Asus X200MA Motherboard Replacement: step 14, image 3 of 3
    • Lift and pull the motherboard out from the hard drive and remove it from the base plate.
2 other people completed this guide.
Alli Krininger
391 Reputation
3 Guides authored
IUPUI, Team S2-G4, Stella Fall 2019 Member of IUPUI, Team S2-G4, Stella Fall 2019
IUPUI-STELLA-F19S2G4
4 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 1,239
